Go to Post The problem was too many penalties with too much room for judgment. - dbSparx [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 22-07-2010, 16:58
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: Chassis Connections
This year, we used lots and lots of bolts. Our whole robot was basically various sizes of aluminum angle, so we just had angle inside angle bolted together with at least 2 bolts.
In the past, we have welded (only drivetrains), used gussets and rivets, and used 80/20 extrusion.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 22-07-2010, 17:13
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
1350 uses bolts and nyloc nuts everywhere. It makes prototyping easy since we can easily build, test, and rebuild any part (easy until you find you built an integral structural or functional component directly over the bolt head you need to get to which can't be moved since EVERYTHING is bolted onto it, but thats OK, it builds dexterity). The real issue comes when everyone is fighting to use one drill bit or wrench that is the only one of its size and happens to be the correct one for EVERY bolt on the robot.
We also like zip-ties, but not so much for the chassis.
Encoder Connections TonyP CAN 1 08-02-2010 22:26
Jumper Connections Lord Byron Electrical 4 26-01-2009 20:43
Field Connections? xxMORT11xx FRC Control System 4 24-01-2009 21:51
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
