Go to Post John Abele certainly deserves much more recognition than he gets. - Richard Wallace [more]
Unread 23-07-2010, 14:04
davidc10 davidc10 is offline
FRC #0423
davidc10 will become famous soon enough
Problem with Async VI Agent.vi staying alive
I'm having a problem when using the Wait function from the Interrupt palatte.
The problem seems related to the Async VI Agent.vi staying alive when the calling VI goes idle.
I've attached a small VI to demonstrate the problem.
The same type of problem has occurred when I have run projects based on some of the example code - and the only work around I've found is to use an Abort Invoke Node on Async VI Agent.vi when my top level VI closes. (But this required changing the library scope of Async VI Agent.vi from Private to Public, which is not an acceptable fix.)
Thanks,
David
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
IT'S ALIVE!!!!!!!! WE HAVE CONQUERED ALL THE WORLD WITH THESE!!! sgsdragons Robot Showcase 23 13-03-2006 14:46
IT'S ALIVE!!!!!!! WE WILL CONQUER THE WORLD WITH THESE!!!!!! (Part 2) THE MOVIE sgsdragons Robot Showcase 20 16-02-2006 10:46
Free Agent Mentor. iceman_21 General Forum 2 25-09-2002 23:41
Staying with Seattle Ken Loyd General Forum 5 09-11-2001 23:52
