#30
Re: Chassis Connections
A very easy method for creating a chassis would be to use 1"x1"x1/16" aluminum tubing with Brunner Connectors. In order to secure the pieces together, we use 1/8" thick aluminum gussets with sheet metal screws.
This method allows easy modification of your chassis without having unweld or cut away pieces. |
| Encoder Connections | TonyP | CAN | 1 | 08-02-2010 22:26 |
| Jumper Connections | Lord Byron | Electrical | 4 | 26-01-2009 20:43 |
| Field Connections? | xxMORT11xx | FRC Control System | 4 | 24-01-2009 21:51 |
| New AM C-Base Chassis vs. Old IFI KitBot Chassis? | ChuckDickerson | Kit & Additional Hardware | 5 | 06-01-2009 08:36 |
| Frame connections | manleycor | Technical Discussion | 15 | 18-11-2003 01:14 |
