Go to Post I have never gone to a FIRST Robotics competition and not had fun. - mathking [more]
Unread 23-07-2010, 19:12
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
Spur Gear size control
I've been trying to create spur gears of specific sizes, but I can't figure out how to control the size of the output for the spur gears. Can anyone help?
Latin:
"Murmure ventus erit parere Tempestatem"
"Noctu teneris vinculis
Nocte illa vincula adimuntur"
Unread 23-07-2010, 20:37
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Spur Gear size control
Are you using Inventor's design accelerator to make the spur gears? I just assume this based on the description of your situation.
If so I would recommend not. I have tried it before and it is confusing to work with and easier to just draw the gear yourself.
Unless you plan to make your own gears (in which case you can do whatever you want), I just create one of the teeth and circular pattern it around the part. Copy geometry from a gear you find from a vendor of gears.
If you're in SolidWorks or ProE you have to draw them yourself anyway...which is for the better since in my opinion it is an easier way to make a gear.
Unread 23-07-2010, 21:02
Chris is me's Avatar
AKA: Pinecone
I find it a lot easier to make cylinders at PD than to make gears for modeling purposes. Less pretty, but a lot easier to change when you inevitably decide to gear your drive differently.
Unread 23-07-2010, 21:12
AdamHeard's Avatar
Lead Mentor
Solidworks will generate gears and sprockets, along with many other items.
However, I agree that just the Pitch diameter is the way to go; adding teeth just unnecessarily adds features to your model.
Unread 24-07-2010, 02:18
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
If you're using inventor you can get a user definable gear from First Cad Library.
Here is the direct link for the I-Spur Gear.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 24-07-2010, 23:43
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
In SolidWorks, create two configurations of the spur gear
1. Just pitch diameter (simplified)
3. With teeth if needed for visualization
If you what to test gear ratios in the assembly, use a Gear Mate with the simplified version, enter the ratio.
To see how a spur gear is created, in a new assembly insert a gear from Toolbox, then enter in pitch, teeth, pressure angle and all the other parameters. When you are learning - just take default on everything and then see what varies.
You can create the profile of a spur gear tooth based on sine and cosine functions - but this is really overkill and will bog down any large assembly in robot design.
Keyang Motor Spur Gear Pitch Dan Petrovic Technical Discussion 4 24-01-2012 21:35
Metal Spur gear for Keyang motors Bochek Motors 9 19-02-2008 08:43
Different types of spur gear stock Travis Schuh Technical Discussion 6 02-01-2008 11:47
Spur gear to go CIM for 56mm Banebots John Gutmann Motors 5 30-05-2007 13:45
Spur Gear Rod? David Guzman Technical Discussion 6 18-01-2006 22:53
