Go to Post Let's let FIRST bring us together as a whole rather than separate us into parts eh? - sanddrag [more]
Unread 20-07-2010, 22:12
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
Materials for FRC
I have not come across a good listing of materials (plastics, metals, fibers, composites, etc.) routinely used in FRC robot construction. By good, I mean one source that gives information about specific materials: how to work with it, tips and tricks, and its mechanical, electrical and thermal properties.
I would like to know if such a white paper/presentation would be of interest to the CD community. If so, what materials and properties would you like to see included. Tips and tricks on working with various composite materials would be greatly appreciated.
Unread 20-07-2010, 22:57
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: Materials for FRC
Information about materials is actually one of the things I find is pretty easy to locate on the internet, on places like matweb.
It might be more useful to make a presentation on how to use the material properties available, and what they mean. I have wanted to write something such as this for a while, but have been waiting to know more about this topic (IE, I want to finish my second materials course in Uni and get some MODS behind me). If you are interested in collaborating on something, just PM me.
Another thing that might be useful would be some graphs of common FRC materials for Specific Strength vs. Cost, and other stuff like that that might aid in design decisions.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 21-07-2010, 10:15
lbarger's Avatar
AKA: Lee Barger
Alex, your points are well taken. However, I am hoping to take the information one step further than simply listing specific properties, especially with more common materials.
For example, I saw several robots this past season that used acrylic for shielding the electronics. Acrylic is brittle and can shatter on impact. Polycarbonate is much better suited for this role. Also, while both materials are clear plastic, it is relatively easy to identify the two without potentially destructive testing. The edges of cleanly cut acrylic sheets are usually bright because it is very clear optically. On the other had, the edge of a polycarbonate sheet is typically a dark purple. Furthermore, with polycarbonate, while it is great for impact loads, it does not fair well under constant loading: tighten screws too much and in a few days you will see star burst like fractures.
Unread 21-07-2010, 10:30
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Sounds like a fantastic idea. I'm sure plenty of people, myself included, would help contribute if you desired.
I would focus on aluminum and steel alloys. Things like strength-to-weight and stiffness-to-weight, weldability, machineability, and cost would be good parameters to discuss.
Unread 23-07-2010, 20:16
ThaineP
Posts: n/a
We used plywood and aluminum (bar and angle stock) this year, along with some steel (Tube stuck? Square stock? Little help here?) and the C-channel in the KOP.
We had a robot with a aluminum C-channel chassis, and a half-inch piece of plywood to hold electronics/pneumatics. Our kicker and kicker mounting were made of steel, and we had a plywood-and-aluminum angle stock sticker-ed 'tent' as a roof for the electronics, which, I must say, looked pretty cool.
I found that steel is very hard to cut but very strong and won't bend with any of the impacts we took (even with me driving) Unless you have a circular saw, I'd recommend that you go with aluminum in the pit, because a hacksaw takes considerably longer with steel than aluminum. You have to go slow on a drill, with the speed up high, way high. (careful, the holes get hot then)
Plywood is a piece of cake to cut, but don't use a metal blade for it. Drills go through fine, too, but sometimes get stuck. I wouldn't recommend it for structural material, because it will break reasonably easily and splinter.
For aluminum, a hacksaw with a metal blade works fine, and drills go through on a high speed setting reasonably well. Definitely don't use aluminum bar stock for major structural stuff, because it bends easily (our ball magnet bent it almost three inches back) Angle stock works much better, and looks cleaner.
For all of these, remember to deburr holes and file edges, and PLEASE PLEASE PLEASE don't cut them anywhere near electronics!!! We lost a couple of JAGUARs this way! Also, when using screws in wood, make sure not to sink the heads in too far, as this will cause the backside to splinter some times, and make the screws easier to rip out. Don't tighten screws in aluminum too much either, because aluminum bends easily and this could cause the structure to warp.
Hope this helps
Thaine
Unread 23-07-2010, 21:13
Chris is me's Avatar
AKA: Pinecone
It would be cool to see an inclusion of pultruded fiberglass and wood. Both can be used in a lot of places but few know the advantages and drawbacks of either. If you'd like some input on the former drop me a PM.
The only thing I would list acrylic for would be to state that one should never, ever use it on a robot.
Unread 23-07-2010, 22:48
lbarger's Avatar
AKA: Lee Barger
Thaine,
Thanks for the description, it is helpful to know how others build their robots.
As far as your question on terminology, "square stock" usually refers to solid square extrusions. (A more generic term would be "bar stock" which includes rectangular cross sections.) Though many people use the term "tube stock" it does not explicitly define the geometry as there are round, square and rectangular tubes (along with more complex shapes). For hollow, square extrusions I prefer to use the term "square tubing" or "square tube". Hope this helps.
Unread 23-07-2010, 22:50
AdamHeard's Avatar
Lead Mentor
We've had good success mounting polycarb with lots of rivets (to spread the load) or mounting it with velcro.
Unread 23-07-2010, 23:11
I've been using that for about two years now and definitely recommend it. I find myself using it very often for work too.
Unread 24-07-2010, 00:00
PriyankP's Avatar
PriyankP PriyankP is offline
FRC #0188 (Woburn Robotics)
PriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud of
http://frcsupplierscanada.wikispaces.com/
A page Mr Lim started! (I believe its still under construction) It would be most useful to a Canadian team.
Champs Schedule Highlighter App [CD Thread]
#### XYZ Regional Finalists
Unread 25-07-2010, 10:55
Dick Linn's Avatar
no team (Synergy)
Lee,
That's an ambitious project and a good one. Perhaps it could be broken down into topics/chapters by material and you could solicit input here on one topic at a time. A good outline of the desired content would help -
available forms & cost
strength/weight
stiffness
workability
alloys and variants
forming/machining/welding/gluing
sources
links to application notes & technical data
tips & techniques
application examples
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 25-07-2010, 18:16
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I'm highly interesting in starting a powerpoint for this. If anyone would like to or a group of people, we could always start a google presentation for this?
If anyone is interested, send me an email.
-RC
R.C.
MadTown Robotics Team 1323
Unread 26-07-2010, 13:59
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Hello all,
I've volunteered to help R.C. (and whoever else would like to join) organize this project. Currently, we're trying to determine a layout/organizational structure. Thus far, people have mentioned the following:
Materials
Metals: including steel and aluminum alloys
- C Channel (U Channel)
- Bar/Rod Stock
- Tube Stock (including circular & rectangular)
--I'd like to add Angle and 80/20 T-Slots to this list
Polymers, Plastics: including acrylic and polycarbonate
--This could delve into things like belting: polycord, latex, etc if anyone was interested. (I don't have the background to do this in full)
Wood: including plywood
Fibers
Composites
Topics
Basic Properties (values, meanings, uses)
- Mechanical
- Electrical
- Thermal
- Identification Techniques
Correlations [by material and stock shape/dimensions]
- Strength vs. Cost (and cost in general)
- Strength vs. Weight
- Stiffness vs. Weight
Uses
- Forming
- Machinability
- Weldability and/or Adhesives
- Fasteners & Tools
- Tips & Tricks, including Safety
Sources/Suppliers (?)
This should be a really good project! Does anyone have any comments, suggestions, etc on the layout (i.e. the table of contents)? Would you like to add anything to the list or volunteer for a section? R.C. is making a Google Doc, the link will probably be up shortly.
Unread 26-07-2010, 19:58
lbarger's Avatar
AKA: Lee Barger
Originally Posted by Siri View Post
Hello all,
That is the whole reason I started this thread!
The knowledge of the CD community is much more vast than the knowledge of any single individual. However, having no experience with open documents and being a registered Professional Engineer, I am curious to learn how one can ensure the accuracy of information provided by 'the public'. If the information is not accurate, it could be worse than useless. It could be harmful.
I strongly encourage a white paper format versus a presentation. Done correctly, there would be just too much information to throw at people in one sitting. Besides, most people would only need information on a select few materials. Its just that there are so many material available, each with good and bad qualities. One or more presentations could be condensed from the white paper once it has a good selection of material.
The outline I have is divided into chapters based on material types. Within each chapter, the paper would discuss the different variants available in more detail. Based on input I've seen thus far and my own ponderings, the guide is looking something like...
Chapter I: Aluminum
Chapter II: Steel
Chapter III: Plastics
Chapter IV: Composites
Chapter V: Wood and Fibers (non-composites)
Chapter VI: Lubricants
Chapter VII: Rubber/Elastomers?
Chapter VIII: Misc (If it doesn't fit anywhere else...)
Within each material class, we should highlight the most commonly used variants and variants with unusually good characteristics. (A Variant would be a specific aluminum or steel alloy, specific plastic or wood, etc.)
1) General Description and Identification Techniques
2) Mechanical Properties
3) Electrical Properties
4) Thermal Properties
5) Available forms (i.e. u channel, bar, rod, tube, powder, corrugated. t-slots, cable), sources and cost
6) Rating on forming, machining, welding, gluing, etc.
7) Links to application notes & additional technical data
8) Uses/Tips and tricks for use within FRC (1 hour repairs?, safety, fasteners and tools)
9) Application Examples
10) When to avoid use? (probably under safety)
I hesitate on including correlations (Strength vs. Cost, Strength vs. Weight and Stiffness vs. Weight) as these involve both material properties and geometric forms. This could/should be a complete white paper in itself.
Unread 26-07-2010, 20:44
Siri's Avatar
Dare greatly
Lee,
Firstly, are you not invited on the Google Doc? (Apologies, I thought you were.) If you'd like to be, I think R.C. can fix that. Sorry
Public Editing: Good question. Google Docs is actually pretty good about this. Currently, the working document is private, so it's only editable to people (or rather, email addresses) who are expressly given permission. However, the presentation itself can be made visible (not editable) to the general public, if desired. This reduces the danger of 'publicly provided' information to that of any other well-informed CD discussion. Does that seem suitable? Of course, it can also be exported in a variety of formats and published on CD-Media as well.
I'd like to see this end up as a white paper as well. It's easy enough to create a Google text document, either in tandem with the presentation or afterward. However, Google Docs has some trade-offs for presentations versus text documents. Personally, I've found that presentations are easier to keep organized with multiple editors, given the different actual slides. Text docs are just one long sheet, though you can insert horizontal lines or even make multiple documents. Presentations can to be nicer to photos/graphs as well, though they tend to crash the longer they get and the more people edit them simultaneously (more so than text docs).
Given this, I'd wonder if we don't want a text document for each chapter, with the presentation having the "gloss" version R.C. was looking for. Actually, I usually make section-by-section 'scrapsheet' documents and then open 'final' doc(s) once all the information is mostly gathered. (It really aids with organization.) Feel free to correct me: Google Docs I'm pretty good with, but I'm no P.E.
The outline I have is divided into chapters based on material types. Within each chapter, the paper would discuss the different variants available in more detail. Based on input I've seen thus far and my own ponderings, the guide is looking something like...[list]...Within each material class, we should highlight the most commonly used variants and variants with unusually good characteristics. (A Variant would be a specific aluminum or steel alloy, specific plastic or wood, etc.)...[list]
This is about what I was thinking (sans lubricants, that's a good idea). Would you like me to make these chapter documents, or should I hold off?
Good point. Personally, I haven't really thought about a length limit (or a number-of-papers limit, for that matter). If there's interest in pursuing this angle, I think it'd be useful, but need not be in the same paper. Honestly, I was just going to link to whatever charts I found, but I don't really know enough about the analysis to expound much further anyway.
Need brochures and materials for 8/17/07! vivek16 General Forum 7 16-08-2007 17:02
need ideas for light weight materials team 1094 Control System 13 04-05-2007 09:34
**FIRST EMAIL**/2007 FRC Manual Decryption and Bill of Materials Information Mark McLeod FIRST E-Mail Blast Archive 33 05-01-2007 14:17
Materials for traction parteyboy10 Rules/Strategy 1 13-01-2003 21:15
Another great source for materials archiver 2000 2 23-06-2002 22:51
