Go to Post This is real. This is hard. This, is FIRST. - sanddrag [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 24-07-2010, 08:24
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Chassis Connections
15 pounds is a bit much for a drive chassis, we usually end up with a welded aluminum frame around 7 pounds.
...which is less than 15lbs last time I checked
Do you have a picture of this 7lb aluminum frame?
Encoder Connections TonyP CAN 1 08-02-2010 22:26
Jumper Connections Lord Byron Electrical 4 26-01-2009 20:43
Field Connections? xxMORT11xx FRC Control System 4 24-01-2009 21:51
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
