Go to Post After the norovirus outbreak at VCU, we had our entire team sterilized. Oh, wait, that doesn't sound right... - dlavery [more]
Unread 25-07-2010, 13:45
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
comparing integer lists
I have two small arrays of integers. (I don't expect more than 16 elements in each array) No integer occurs more than once in an array. Integers are sorted from least to greatest, though they are not necessarily consecutive.
What's an efficient way to diff them, so I get the elements in each array that aren't in the other?
(I do want two resulting arrays, for the elements that were only in array 1, and only in array 2)
The simple way I thought of was to iterate through the first away searching for matching elements in the second array. If one is found, both elements are deleted. The remaining arrays are the elements that were only in each array.
-- Marshal Horn
Should we really be comparing Breakaway to soccer? XaulZan11 Rules/Strategy 9 13-02-2010 15:22
Merging/Comparing LabVIEW VIs Terry Sherman NI LabVIEW 7 30-08-2009 10:30
Comparing Sensor Readings in NQC ZACH P. Programming 5 30-08-2003 17:33
Integer Number powercat Programming 2 18-02-2003 11:26
Spreadsheet comparing ALL First motors Nuts4FIRST Motors 0 08-01-2002 09:20
