Go to Post the rookies come up with amazing stuff (I have seen it happening), they amaze me at times. - Arefin Bari [more]
Unread 25-07-2010, 14:29
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: comparing integer lists
Is this LabView, Java or C++??
In Java (the only language I know), I would use nested for loops that would compare an element in the first array wiht each element in the second array. An example is below, where any number that is found in the other array is changed to -1.
    public class ArraySort
       public static void main(String[]args)
         int[] num1={1,3,4,5,6,8,10,15,19,20,55,99,100,115,156,205};
         int[] num2={0,2,3,4,6,7,10,19,20,45,55,65,100,156,200,256};
      //check for equal variables, if one is found, set element to -1
         for(int x=0; x<num1.length; x++)
            for(int a=0; a<num2.length; a++)
               if(num1[x]==num2[a])
                  num1[x]=-1;
                  num2[a]=-1;
         	//print the arrays
            System.out.print(num1[x]+" ");
         System.out.println();
         for(int x=0; x<num2.length; x++)
            System.out.print(num2[x]+" ");
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Should we really be comparing Breakaway to soccer? XaulZan11 Rules/Strategy 9 13-02-2010 15:22
Merging/Comparing LabVIEW VIs Terry Sherman NI LabVIEW 7 30-08-2009 10:30
Comparing Sensor Readings in NQC ZACH P. Programming 5 30-08-2003 17:33
Integer Number powercat Programming 2 18-02-2003 11:26
Spreadsheet comparing ALL First motors Nuts4FIRST Motors 0 08-01-2002 09:20
