Go to Post We should be celebrating every potential new science and technology leader regardless of which number is on his/her t-shirt. - Dmentor [more]
Unread 25-07-2010, 13:45
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
comparing integer lists
I have two small arrays of integers. (I don't expect more than 16 elements in each array) No integer occurs more than once in an array. Integers are sorted from least to greatest, though they are not necessarily consecutive.
What's an efficient way to diff them, so I get the elements in each array that aren't in the other?
(I do want two resulting arrays, for the elements that were only in array 1, and only in array 2)
The simple way I thought of was to iterate through the first away searching for matching elements in the second array. If one is found, both elements are deleted. The remaining arrays are the elements that were only in each array.
-- Marshal Horn
Unread 25-07-2010, 14:29
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: comparing integer lists
Is this LabView, Java or C++??
In Java (the only language I know), I would use nested for loops that would compare an element in the first array wiht each element in the second array. An example is below, where any number that is found in the other array is changed to -1.
    public class ArraySort
       public static void main(String[]args)
         int[] num1={1,3,4,5,6,8,10,15,19,20,55,99,100,115,156,205};
         int[] num2={0,2,3,4,6,7,10,19,20,45,55,65,100,156,200,256};
      //check for equal variables, if one is found, set element to -1
         for(int x=0; x<num1.length; x++)
            for(int a=0; a<num2.length; a++)
               if(num1[x]==num2[a])
                  num1[x]=-1;
                  num2[a]=-1;
         	//print the arrays
            System.out.print(num1[x]+" ");
         System.out.println();
         for(int x=0; x<num2.length; x++)
            System.out.print(num2[x]+" ");
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 25-07-2010, 14:38
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
Say the arrays are labled 'A' and 'B'. Just two pointers 'a' and 'b' (pointing in their respective arrays). Without loss of generality, say that 'B' starts with a larger element. Keep on advancing 'a' until *a < *b is no longer true. As these arrays are sorted, these values must be unique to A. Now advance 'b' in a similar manner. In the case where *a == *b, advance both pointers. Don't output the element as it exists in both.
Alternately, add all elements of A into a hashtable. Now iterate through B outputting all elements that are not in the hashtable.
Both algorithms have the same asympotic complexity but the first doesn't require any extra memory and should run a bit faster.
Here is algorithm 1
#include <stdio.h>
#include <stdlib.h>
void mydiff(int * arr1, int * end1,  int * arr2, int * end2, int * diff1, int* diff2);
int main() {
	int arr1[] = {2, 4, 5, 6, 7, 8, 20, 33, 34, 56};
	int arr2[] = {1, 2, 6, 7, 8, 10, 11, 45, 98};
	int * diff1 = calloc(sizeof(int), 10);
	int * diff2 = calloc(sizeof(int), 9);
	mydiff(arr1, arr1 + 10, arr2, arr2 + 9, diff1, diff2);
	printf("diff in arr1:\n");
	while(*diff1) {
		printf("%d ", *diff1);
		diff1++;
	printf("\ndiff in arr2:\n");
	while(*diff2) {
		printf("%d ", *diff2);
		diff2++;
void getTail(int * arr, int * end, int * diff) {
	while(arr != end) {
		*diff = *arr;
		diff++;
		arr++;
void mydiff(int * arr1, int * end1,  int * arr2, int * end2, int * diff1, int * diff2) {
	if(arr1 == end1) {
		getTail(arr2, end2, diff2);
		return;
	if(arr2 == end2) {
		getTail(arr1, end1, diff1);
		return;
	while(*arr1 < *arr2 && arr1 != end1) {
		*diff1 = *arr1;
		diff1++;
		arr1++;
	while(*arr2 < *arr1 && arr2 != end2) {
		*diff2 = *arr2;
		diff2++;
		arr2++;
	if(*arr1 == *arr2) {
		if(arr1 != end1)
			arr1++;
		if(arr2 != end2)
			arr2++;
	mydiff(arr1, end1, arr2, end2, diff1, diff2);
Unread 25-07-2010, 18:18
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
With only 16 elements, the major factor in performance is going to be the implementation details rather than the actual algorithm so the following is more of an academic exercise. You probably won't notice any kind of difference in run time.
Leveraging the facts that a) the arrays are already sorted and b) there are no repetitions in the individual arrays, you can use a stack-matching algorithm. This will run in O(max(n,m)) time instead of the naive methods which will run O(n*m) for arrays sizes n and m. Here's implementations in C and Java.
#include <stdlib.h>
#include <stdio.h>
/* Selects the unique elements between two arrays
 * in1 is the first array
 * in1end is the pointer to past the end of the first array
 * in2 is the second array
 * in2end is the pointer to past the end of the second array
 * out1 is the first output array
 * out2 is the second output array
 * returns the number of common elements, so
 * length(out1) = length(in1) - result;
 * length(out2) = length(in2) - result;
int unique(register int *in1, int *in1end, int *in2, int *in2end, int *out1, int *out2)
	register int common = 0;
	register int val1 = *in1, val2 = *in2;
	for(;;)
		if (val1 < val2)
			*(out1++) = val1;
			if (++in1 > in1end)
				break;
			val1 = *in1;
		else if (val1 > val2)
			*(out2++) = val2;
			if (++in2 > in2end)
				break;
			val2 = *in2;
		else
			common++;
			if ((++in1 > in1end) || (++in2 > in2end))
				break;
			val1 = *in1;
			val2 = *in2;
	while(in1 < in1end)
		*(out1++)=*(in1++);
	while(in2 < in2end)
		*(out2++)=*(in2++);
	return common;
int main(int argc, char *argv[])
	int *arr1, *arr2, *out1, *out2;
	int i, common, len1, len2;
	if (argc!=3)
		printf("Usage: %s <first length> <second length>\n", argv[0]);
		return 1;
	/* read lengths */
	len1 = atoi(argv[1]);
	len2 = atoi(argv[2]);
	/* allocate array space */
	arr1 = malloc(len1*sizeof(int));
	out1 = malloc(len1*sizeof(int));
	arr2 = malloc(len2*sizeof(int));
	out2 = malloc(len2*sizeof(int));
	/* create two arrays of strictly increasing elements */
	srand ( time(NULL) );
	arr1[0] = rand() % 3;
	for(i=1; i < len1; i++)
		arr1[i] = arr1[i-1] + (rand()%3)+1;
	arr2[0] = rand() % 3;
	for(i=1; i < len2; i++)
		arr2[i] = arr2[i-1] + (rand()%3)+1;
	/* print initial contents of the arrays */
	printf("\nArray 1\n");
	for(i=0; i < len1; i++)
		printf("%d\n", arr1[i]);
	printf("\nArray 2\n");
	for(i=0; i < len2; i++)
		printf("%d\n", arr2[i]);
	/* run algorithm */
	common = unique(arr1, arr1+len1, arr2, arr2+len2, out1, out2);
	/* print results */
	printf("\n%d common elements\n", common);
	for(i=0; i < len1-common; i++)
		printf("%d\n", out1[i]);
	for(i=0; i < len2-common; i++)
		printf("%d\n", out2[i]);
	/* free memory */
	free(arr1);
	free(arr2);
	free(out1);
	free(out2);
import java.util.Arrays;
import java.util.ArrayList;
import java.util.Iterator;
import java.util.Random;
public class Unique<E extends Comparable<E>>
	private ArrayList<E> out1, out2;
	public Unique(E[] in1, E[] in2)
		int len1 = in1.length;
		int len2 = in2.length;
		out1 = new ArrayList<E>(len1);
		out2 = new ArrayList<E>(len2);
		Iterator<E> it1 = Arrays.asList(in1).iterator();
		Iterator<E> it2 = Arrays.asList(in2).iterator();
		E cur1 = it1.next();
		E cur2 = it2.next();
		for(;;)
			int comp = cur1.compareTo(cur2);
			if (comp < 0)
				out1.add(cur1);
				if (!it1.hasNext())
					out2.add(cur2);
					break;
				cur1 = it1.next();
			else if (comp > 0)
				out2.add(cur2);
				if (!it2.hasNext())
					out1.add(cur1);
					break;
				cur2 = it2.next();
			else
				if (!it1.hasNext() || !it2.hasNext())
					break;
				cur1 = it1.next();
				cur2 = it2.next();
		while(it1.hasNext())
			out1.add(it1.next());
		while(it2.hasNext())
			out2.add(it2.next());
	public ArrayList<E> getOut1()
		return out1;
	public ArrayList<E> getOut2()
		return out2;
	public static void main(String[] args)
		if (args.length!=2)
			System.err.println("Usage: java Unique <first length> <second length>");
			return;
		/* read lengths */
		int len1 = Integer.parseInt(args[0]);
		int len2 = Integer.parseInt(args[1]);
		Integer[] arr1 = new Integer[len1];
		Integer[] arr2 = new Integer[len2];
		Random rand = new Random();
		arr1[0] = rand.nextInt(3);
		for(int i=1; i < len1; i++)
			arr1[i] = arr1[i-1] + rand.nextInt(3)+1;
		arr2[0] = rand.nextInt(3);
		for(int i=1; i < len2; i++)
			arr2[i] = arr2[i-1] + rand.nextInt(3)+1;
		System.out.print("Array 1: ");
		System.out.println(Arrays.toString(arr1));
		System.out.print("Array 2: ");
		System.out.println(Arrays.toString(arr2));
		/* run algorithm */
		Unique<Integer> u = new Unique<Integer>(arr1, arr2);
		/* print results */
		System.out.println(u.getOut1());
		System.out.println(u.getOut2());
Theoretically might run faster with a big array, but leads to a little messier code than, say, [buildmaster5000]'s
EDIT: Just read [Chris27]'s post again. I think I'm doing the same thing he is, just entirely iteratively instead of the combination iterative/recursive approach he took.
--Ryan
FRC 766, 2015-, Mentor
Unread 25-07-2010, 19:05
Chris27's Avatar
AKA: Chris Freeman
My solution isn't really recursive as a modern compiler will turn the tail recursion into iterative code.
It could be rewritten as
	for(;;) {
		if(arr1 == end1) {
			break;
		if(arr2 == end2) {
			break;
			*diff1 = *arr1;
			diff1++;
			arr1++;
			*diff2 = *arr2;
			diff2++;
			arr2++;
			if(arr1 != end1)
				arr1++;
			if(arr2 != end2)
				arr2++;
Unread 25-07-2010, 22:14
You already have some good ideas, and as stated, 16 elements is nothing, but I'll point out that the task is essentially the same as merging sorted tapes. So now you can look it up in some of the classic algo books if you like.
Greg McKaskle
Unread 26-07-2010, 01:16
Let's brainstorm a short list for fun.
I have Knuth's 3-volume set here in the library.
I had a copy of Sedgewick years ago but can't find it. Must have loaned it out without a homing device.
Should we really be comparing Breakaway to soccer? XaulZan11 Rules/Strategy 9 13-02-2010 15:22
Merging/Comparing LabVIEW VIs Terry Sherman NI LabVIEW 7 30-08-2009 10:30
Comparing Sensor Readings in NQC ZACH P. Programming 5 30-08-2003 17:33
Integer Number powercat Programming 2 18-02-2003 11:26
Spreadsheet comparing ALL First motors Nuts4FIRST Motors 0 08-01-2002 09:20
