Go to Post I think with 1114 & 217 as our partners we could have won with my refrigerator on the field. - JVN [more]
Unread 28-07-2010, 15:05
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
Failed to connect to target Error
Hey we are using windriver and after we set up the environment the robot failed to connect to the crio. We have reimaged the crio for windriver correctly with the correct driverstation update. We are just not sure what went wrong.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 28-07-2010, 15:41
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Failed to connect to target Error
Looks like you have the IP address set to 10.8.43.2. If you are following the documented network conventions, you should be trying to connect to 10.8.42.2
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 28-07-2010, 16:07
John Rangel
its a practice bot so we changed everything to 843.
2014-? Mentor
Unread 28-07-2010, 16:56
Aren Siekmeier's Avatar
on walkabout
Is everything set to 10.08.43.* (router, cRio, wireless bridge, driver station, laptop from which you are running code)? If not, the cRio won't be able to connect to the router. Also, make sure each device has the correct last digit. I think the radio is .1, the router is .4, the cRio is .2, the DS is .5, etc., but you should check. It can be found in the Control System Manual, Chapter 2. You may as well check that you have all the updates too.
Even if everything is 10.08.43.*, I can't guarantee it will work (anyone know more about this?). You might as well change back to 10.08.42.* so that it's ready for use in competition, especially since it's unlikely you will have both systems running at the same time.
Unread 28-07-2010, 17:04
John Rangel
It is likely because we practice with offense and defense but we are able to connect on the driver station and are able to ping the crio.
2014-? Mentor
"Failed to load shared library FRC_UserProgram.out on RT target device" Tristan Lall NI LabVIEW 3 19-03-2010 22:34
Crio: failed to conect to real time target DJ KELLEY Programming 2 27-01-2010 21:43
Failed to Connect after reinstall Blooper4912 C/C++ 2 07-02-2009 13:04
Cannot connect to the Real-time target Mr. E FRC Control System 13 02-02-2009 20:47
[Windriver] Getting error on run: Download Failed JHale C/C++ 4 15-01-2009 07:42
