Go to Post It goes back to what Dave said last year--you can be legal and graciously professional, but still dumb. Play smart. - Billfred [more]
Unread 30-07-2010, 06:17
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Mabuchi Motor Mounting
Hello CD!
We were finishing our new ball control today and I mounted it by putting a rather large bolt through the motor. Now, I know what you're thinking (), but it was the only wait I could do it.
The new motor replaces the old FisherPrice and I'm not sure whether it's the bolt or something else causing the motor to stall. It turns freely by hand, but skips at a regular interval.
Any advice?
Unread 30-07-2010, 11:08
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Mabuchi Motor Mounting
Could you post a picture of the mounting?
It could be the bolt. Or something else could have been broken inside either by the bolt or inside. When you were turning it by hand the debris inside could be out of the way. However when you have it mounted it could have shifted in a place where it is stalling the motor.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 30-07-2010, 11:09
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Almost definitely the motor is hitting the bolt. You're going to have to shorten the bolts. The factory mounting points allow bolts to hit the armature/fan inside the motor can if the bolts are too long, I've done this before.
Unread 30-07-2010, 14:55
Chris is me's Avatar
AKA: Pinecone
Putting a bolt through a motor (as in by drilling a hole through it, not by using the Mabuchi's mounting holes!) would change its performance and make it not so FIRST legal anymore.
Unread 31-07-2010, 05:13
We tested the robot today and if we enable the motor while driving, the robot stops responding to input until we release the trigger, making the motor stop receiving current.
Unread 31-07-2010, 15:19
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
i would guess that when the electromagnet in the motor is turned on it causes something to strike the motor in a way that shorts it or jams it.
Unread 31-07-2010, 18:01
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
The bolt is either shorting it, or causing it to stall, both drawing too much current, and causing the system to stall.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 31-07-2010, 19:55
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
This could be indicative of either a software or a hardware problem.
Try unplugging the motor controller and pressing the same trigger, does this cause the same loss of control?
Unread 02-08-2010, 07:44
In almost every case of drilling into the motor case, shavings will be attracted by the internal magnet and find their way between the magnet and the armature. When you apply current, those shavings will then stand up and align with the magnetic field between the armature and the magnet usually causing some kind of mechanical friction. It is also likely that you have dislodged the magnet or cracked a piece off internal to the motor. Either way that will also produce significant internal friction when current is applied. The robot rules prevent modifying the motors (among other things), for just this kind of damage.
Unread 02-08-2010, 09:06
Thanks everyone. I'll go check out the motor this weekend when the mech lab's open. Oh and there was no drilling involved, it was just a bolt through the mounting holes.
Mabuchi Motor replacement AdamHeard Technical Discussion 8 01-02-2010 13:52
Mabuchi Motor Supplier RMS11 Motors 10 28-01-2010 23:22
2005 Mabuchi Motor DarkJedi613 Motors 1 07-02-2006 15:43
Mabuchi Motor Paul Copioli Motors 1 08-01-2002 10:26
