Go to Post Comments and Documentation: Use them! You would never believe how fast you will forget how something works, especially when things are flying at you so fast. Other/future programmers will understand what you did and why you did it. - BigJ [more]
Unread 01-08-2010, 18:24
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
DS "User Message"
The "User Message" on the Driver Station is just a string indicator, right?
Does it word-wrap and scroll like a normal string indicator, or does it have some processing on it to make it act like a primitive LCD text display?
-- Marshal Horn
Unread 01-08-2010, 19:00
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: DS "User Message"
I assume you mean the one on the overview page of the DS
IIRC, that one has a limit on how far text can go on and will cut it off with a ... and not wrap
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 01-08-2010, 21:26
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
I tested and confirmed this with line 1.
Unfortunately, that makes it useless to me.
I guess I'll just have to use the error messages window.
I'm making a CAN startup test, and want to send the results back to the driver. However, I'd rather not make anyone who uses this startup test have to fit this into their dashboard. I only plan to send the message once at the start of Autonomous Enabled.
-- Marshal Horn
Unread 01-08-2010, 23:42
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
If its your own message, then why can't you make it fit within the length of the box?
You could use multiple lines.
[edit]
Or, you could use this:
public class DriverStationLCDwWrap  {
    private static DriverStationLCD lcd = null;
    private static DriverStationLCDwWrap LCDw = null;//keep the singleton pattern going
    private DriverStationLCD.Line[] lcdLines =
    {DriverStationLCD.Line.kMain6, DriverStationLCD.Line.kUser2,
     DriverStationLCD.Line.kUser3, DriverStationLCD.Line.kUser4,
     DriverStationLCD.Line.kUser5, DriverStationLCD.Line.kUser6};
    private DriverStationLCDwWrap()
        lcd = DriverStationLCD.getInstance();
    public static DriverStationLCDwWrap getInstance()
        if(LCDw == null)
            LCDw = new DriverStationLCDwWrap();
        return LCDw;
    public void updateLCD()
        lcd.updateLCD();
    public void println(String text)
        int length = text.length();
        int lines  = length / lcd.kLineLength;
        String blank = "                      "; // 21 spaces, clears the line.
        for(int i = 0; i < i < lcdLines.length; i++)
            lcd.println(lcdLines[i], 1, blank); // Clear the all lines of previous text
        for(int i = 0; i < (lines + 1) && i < lcdLines.length; i++)
            int start = lcd.kLineLength*i;
            int end   = (start+lcd.kLineLength  >= length)? length : start+lcd.kLineLength;
            lcd.println(lcdLines[i], 1, text.substring(start, end));
        updateLCD(); // call it since the the string has replaced the entire DS LCD buffer
(note, this is character wrapping. Your message can and will be chopped off to a new line)
For example: println("This is a very long message that will be split into several pieces");
becomes:
ces
[/edit]
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 02-08-2010, 13:42
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
I can't because of the amount of information I'd like it to display. (If the startup test can't figure out the issue, then it will return all the configuration and status information it has on the Jaguar. That's a LONG message.)
However, I found a lovely subVI in "StartCommunication.vi" that is a functional global for the DS error messages, so I can write to that without having to evoke and error.
It's called StatusErrorCache.vi.
-- Marshal Horn
Unread 03-08-2010, 20:54
Another option is to write a status message to the LCD (CAN Status: Pass/Fail). Then use the error messages to print all your detailed status when it failed.
We used the LCD for a lot of status messages in that manner, and it was very convenient for that.
"Emergency Stopped" message won't go away Lakedaimon General Forum 25 13-08-2012 22:14
"Demo Stamp not found" error message Gatto Programming 1 07-02-2007 23:17
"The Power of a Positive Team" Message Joe Matt General Forum 2 04-04-2005 09:48
Why would I "subscribe" to a message thread or a forum? Joe Johnson CD Forum Support 4 07-06-2001 22:07
