Go to Post I think this thread just won "ChiefDelphi is terrible Bingo". - Karthik [more]
Unread 29-07-2010, 20:01
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Drop-center drivetrains: Why?
So, this may sound extremely n00bish of me, but I can't seem to see the advantage of a drop-center 6 (or 8) wheel drivetrain over other types.
I understand the point of dropping the center wheel: to reduce friction by making the robot rock so that two wheels are off of the ground. But I can't see why you wouldn't you just have a 4-wheel drivetrain, only 4 wheels are going to actually be touching the ground anyway.
We went with a 6 wheel drive this year, but we lowered the friction by putting omniwheels on the corners of the robot.
Is there some secret purpose that you could enlighten me of?
Unread 29-07-2010, 20:11
NickE's Avatar
NickE NickE is offline
_
Re: Drop-center drivetrains: Why?
With a fixed robot width and fixed wheels all facing forwards, the shorter your wheelbase is, the easier turning will be. This is because the wheels have to scrub less to make the turn.
With a 4WD robot, the wheelbase is quite long, causing difficult turning.
When a 6WD dropped-center robot, only the front four or back four wheels are on the ground at any given time, effectively halving the length of the wheelbase, resulting in easier turning.
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
With a dropped-center 6 or 8 wheel robot the wheels contacting the ground when turning are closer together than on a 4 wheeled robot. Because the wheels are closer together it makes it easier to turn. This is one of the reasons it is easier for wide base robots to turn.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 29-07-2010, 20:18
Chris is me's Avatar
AKA: Pinecone
All of the below assumes a roughly centered CG and even tractioned wheels (all roughtop or wedgetop or kit)
With four equal and high traction wheels on the robot in the long orientation, turning on a dime is basically impossible. It can be done with large wheels and a lot of "jumping", but it's close enough to impossible that the robot's basically worthless.
Adding another set of wheels with no drop fixes this a little bit, but generally not enough without some specialization. 25's drivetrain is an exception due to a lot of subtle reasons I don't really want to go into here.
Dropping the center wheel means that effectively you have shortened your wheelbase by half, since only 4 are on the ground. This makes your wheelbase wider than it is long so you can turn just fine. As a bonus, when you're pushed on one side it's very easy for the robot to "lean" on those wheels to make you harder to spin than, say, the same drivetrain with omni wheels, leading to great pushing resistance.
With a 6 wheel no drop omnis, you get comparable performance and even better turning at the cost of being more easily spun yourself. 4 wheels with 2 traction and 2 omnis exaggerate this effect further. 6 wheel drop is basically the very best of most worlds, for most games.
In the case of a wide body robot, Lunacy demonstrated you don't _need_ 6 wheels to turn well.
Unread 30-07-2010, 01:33
CENTURION's Avatar
Ah, I see now, of course!
I guess I underestimated how much friction the 4-wheel drive created...
Thanks a ton for the insight!
Unread 01-08-2010, 22:10
AKA: Pinecone
No problem.
I felt really, really bad not including "the math" supporting the claim, so here's a link to an excellent paper on the topic of drivetrains that explains all of the phenomena. It never specifically addresses the case of the 6 wheel drop, or what happens if you lower the sideways traction of one of your wheel sets (i.e. if you put omnis on one part of your drivetrain) but it shouldn't be too hard to see how a 6 wheel performs better than a regular drivetrain as a result.
If we're engineers, I feel we shouldn't be content with the what without the why...
http://www.chiefdelphi.com/media/papers/1443
Unread 01-08-2010, 22:48
ditto that !
Unread 02-08-2010, 02:53
AdamHeard's Avatar
Lead Mentor
We're not engineers, small correction. Statement is true otherwise.
Unread 02-08-2010, 07:33
Simply put, without dropping the center wheels, drive motors rapidly go to stall current in turns.
Unread 02-08-2010, 08:19
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Do a little more digging. A common questiont that many 6x6 drop center guys will ask is "How much drop are you using?". While a fair question, the same amount of drop will have various effects on different chassis. CG placement and Chassis stiffness, and overall goals/objectives play a big part into what is considered effective amounts of drop.
Unread 02-08-2010, 09:31
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
As an example, 95 has used dropped center designs when the robot did not have precise manipulators mounted on the chassis, where the robot rocking back-and-forth did not adversely affect controllability. On two robots that DID have bigger arms that needed to be controlled with precision we used omni wheels on the four corners so that the robot was more stable and the arm was easier to control.
EDIT: To avoid confusion, I am talking about a 6wd platform with two traction wheels in the middle, and omni wheels at each corner.
Unread 02-08-2010, 12:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Originally Posted by JamesCH95 View Post
... On two robots that DID have bigger arms that needed to be controlled with precision we used omni wheels on the four corners so that the robot was more stable and the arm was easier to control.
Anecdotal evidence would suggest that rocking drive trains still maintain the maximum manipulator control aspect given a proper c.g. As an example from 2005, 254's robot had a rocking 6WD with a very long 2-PID arm. When fully extended the arm would shift the c.g. slightly, yet when it was down the tetras were easy to pick up because the c.g. stayed towards one side or the other when the robot was not accelerating.
Unfortunately it is exceptionally hard to integrate c.g. from scratch ahead of time; rough estimates are the best I've ever seen derived at the early stages of design. Since drive train is one of the three systems that MUST work (drive train, electronics, programming) in order to do anything effective in a game, most teams prototype like crazy on a pre-season prototype drive train. Additionally, finishing the production drive train early in the season is atypical of actuality for most teams.
Ergo a wise suggestion to anyone worried about c.g. shift on a rocking drive train is to have a pre-season prototype ready to go such that manipulators may be directly mounted to it during build season prototyping. This will give earlier estimates on c.g. and should produce constraints on shifting c.g. that may dictate where to put the 'heavy' elements (compressor, battery, drive train gear boxes, etc) on the production robot.
GitHub
Unread 02-08-2010, 14:48
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
For all of the analysis that could go into a chassis like that it is simpler to use omni wheels on the corners and be done with it. That frees up all the time and energy saved in chassis analysis for use in more unique challenges.
Unread 02-08-2010, 14:54
EricH EricH is online now
It's simpler, unless the game requires pointing in one direction for any length of time (like 2 seconds to unload a game object). The defensive robots love 6WD robots that have omnis on the corners, something about they're easier to knock out of position rotationally.
A pneumatic center wheel on a drop-center is actually a pretty good idea: you can fine-tune the drop a little bit to get exactly the characteristics you want, even between matches.
Unread 02-08-2010, 15:08
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Good point about the defense.
Changing pneumatic tire pressure would also change gearing and grip, but those might also be good things.
pic: Center Player Station and Ball Drop Wetzel Extra Discussion 2 08-01-2006 17:40
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
Omnidirectional drivetrains patrickrd Technical Discussion 21 11-10-2002 10:54
Drivetrains archiver 2001 14 23-06-2002 22:52
