Go to Post If your robot doesn't work, it doesn't matter, because the robot is really meaningless, in the long run. What is the important thing, the reason we're all in FIRST then? To better our understanding of Science and Technology, and hopefully make the world a better place. - Ian W. [more]
Unread 02-08-2010, 16:08
siaohuang siaohuang is offline
siaohuang is an unknown quantity at this point
Error - Invalid 18f8520 header file! Vex Robotics Kit
First of all I'm a newbie at the Vex Robotics Kit here are the things I've already done
I've successfully installed Mplab v8.10 and C18 compiler v3.35 , I went through the user guides and successfully build the first program, the "Hello World!!" program,so I think my C compiler is working
I downloaded the Vex Starter Code and extracted to a file called "VexCode" I placed it under the directory C:\mcc18\VexCode I opened VexUserCode.mcw (work space) and imported VexUserCode.mcp (project)
I set the Project--> Build options ---> Project and set the Include search path to C:\mcc18\h and C:\mcc18\VexCode
and the Library search path to C:\mcc18\lib and C:\mcc18\VexCode
and Linker script search path to C:\mcc18\VexCode the Linker script is in the VexCode folder 18f8520user.lkr
Then Build all in the output window it shows
Debug build of project `C:\mcc18\VexCode\VexUserCode.mcp' started.
Preprocessor symbol `__DEBUG' is defined.
Tue Aug 03 03:19:32 2010
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\mcc18\VexCode\VexUserCode.mcs".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\VexCode" -I"C:\mcc18\h" "user_routines_fast.c" -fo="user_routines_fast.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\mcc18\VexCode\ifi_picdefs.h:1289:Error [1099] *** Error - Invalid 18f8520 header file!
Halting build on first failure as requested.
Debug build of project `C:\mcc18\VexCode\VexUserCode.mcp' failed.
Can anyone solve this? Thank you for you time!!
Unread 02-08-2010, 16:33
Re: Error - Invalid 18f8520 header file! Vex Robotics Kit
Did you install MPLAB/C18 from the VEX CD or did you also download any updates from online?
That error seems to indicate that the ifi_picdefs.h file is being inserted twice. It has a check at the beginning to prevent that though...
Unread 02-08-2010, 17:06
Thanks for your reply I downloaded my Mplab and C18 from
http://www.microchip.com/stellent/id...en023073&part=
I also saw a forum
http://www.chiefdelphi.com/forums/sh...ad.php?t=31255
It seems that we have similar problems in the forum it mentioned something about the macro setting and I also tried adding "_FRC_BOARD" to the macro definitions and it still didn't work
Thanks for reading.
Unread 02-08-2010, 17:21
Thank for your reply I downloaded my Mplab v8.10 and C18 v3.35 from
and i saw the thread that mentioned the macro defintions so i ADDED "_FRC_BOARD" to my macro definitions and it didn't work as well
thanks for replying it means a lot to me!!
Unread 02-08-2010, 18:38
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
#define _VEX_BOARD
is what you want for the VEX board.
Let me recommend that you visit the: WPI Lib for VEX/FRC site and grab that library. It will make your programming about 1000 times easier. There are full instructions on how to make it work with MPLabs.
The Microchip compiler / linker is very fussy when it comes to path names, etc. in the setup.
Keep us posted on how you make out.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 02-08-2010, 18:54
Shouldn't it turn out as pictures?
Unread 03-08-2010, 12:09
Thanks for all you guys' help!! I got it to work I try downloading older versions of Mplab v7.60 and C18 v2.40 and I downloaded Elevation - Appendix D (Programming Guide) from http://www.vexforum.com/wiki/index.php/Elevation
when you extract the file it willgive you the VexCode file and deleting the old library files and adding a new one Vex_2008_library.lib from the MPLAB-Autonomous-Code Rev2 - Vex Code
now when I build the mpw file it gives me
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "user_routines_fast.c" -fo="user_routines_fast.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "ifi_startup.c" -fo="ifi_startup.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "printf_lib.c" -fo="printf_lib.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "user_routines.c" -fo="user_routines.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "ifi_utilities.c" -fo="ifi_utilities.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "main.c" -fo="main.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" "C:\VexCode\18f8520user.lkr" "C:\VexCode\user_routines_fast.o" "C:\VexCode\ifi_startup.o" "C:\VexCode\printf_lib.o" "C:\VexCode\user_routines.o" "C:\VexCode\ifi_utilities.o" "C:\VexCode\main.o" "C:\VexCode\Vex_2008_library.lib" /o"VexUserCode.cof"
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Errors : 0
MP2COD 3.90, COFF to COD File Converter
Errors : 0
MP2HEX 3.90, COFF to HEX File Converter
Errors : 0
Loaded C:\VexCode\VexUserCode.cof.
BUILD SUCCEEDED: Wed Aug 04 00:08:48 2010
once again thanks for all your help!! Happy programming!
Unread 03-08-2010, 14:00
Great!
This error usually seems to be a mismatch between the versions of the C18 software, the Vex libraries, and the program.
Header File Missing BloodSoakedTear Programming 1 26-02-2006 16:54
Error in header file p18f8520.h !!! RbtGal1351 Programming 3 17-01-2005 16:03
error - Invalid 18f8520 header file! vtrehan Programming 2 16-11-2004 08:31
Header File error message Mike Yan Programming 2 09-02-2004 11:31
Needing A header file jweric Programming 19 23-01-2004 10:25
