Go to Post FIRST is nothing short of a community. - karinka13 [more]
Unread 03-08-2010, 12:33
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
LabView and Vex. Are they compatable?
Does anyone know if there is any way to program a Vex control system with LabView. I've done some searching with no recent answers (most recent relevant post was from '07). I have the orange programing cable for the Vex kit so that I can use EasyC but I'd like to use LabView with it.
LabView Version - 8.6 (FRC Version from this year)
Vex Control System - I think I bought it in '06 (non-competition)
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 03-08-2010, 20:41
Re: LabView and Vex. Are they compatable?
There is no (easy) way to program a vex controller with LabVIEW. Back when LabVIEW was provided with the IFI controller, it was for doing other things. In 2006 we used the provided DAQ and LabVIEW for a ball velocity meter.
Unread 03-08-2010, 21:30
FRC #0379
Since your hinting at it being possible I'm going to probably try for a few hours and see what I can figure something out. Might be very difficult as all I have yet to do with LabView is programing this years robot which is relatively simple. Thanks for your help and if I find anything out I'll post it.
Unread 03-08-2010, 21:47
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Sadly, the easiest way might be to translate it into C and then compile it with the MPlab software.
The other option is to buy a 60-day trial of the LabVIEW Embedded module for ARM processors, and work from the ground up with that. However, I don't even know if the VEX platform uses an ARM processor.
-- Marshal Horn
Unread 04-08-2010, 14:13
The VEX Controller v.5 is based on an 8-bit PIC processor. The two new processors are based on the STMicroelectronics ARM Cortex-M3 and the ARM9 processor. Check the VEX website for details. I have NO idea if you can port LabVIEW to either of these controllers.
Unread 04-08-2010, 15:56
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
The term "porting labview" is a bit misleading here.
What's typically done with RISC processors is the language is compiled directly for the processor. The cRIO, on the other hand, is actually running an operating system within which your program runs.
-- Marshal Horn
Unread 04-08-2010, 16:17
I don't understand what you mean. You seem to imply an either/or situation where one does not exist. What you said is akin to "Most cars have four wheels. However, some cars use diesel fuel."
LabVIEW for FRC targets the cRIO's CPU directly and the resulting code is run under the vxworks OS.
Unread 04-08-2010, 20:33
I'm hinting that it would be possible for LabVIEW to be ported for the new vex controller, but it's not anything that could be done in just a few hours, and not without some experienced developers. The FRC version of LabVIEW doesn't include the LabVIEW embedded add-on which would be required to do this. http://zone.ni.com/devzone/cda/tut/p/id/6994
Unread 05-08-2010, 02:38
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Maybe I'm putting too firm a boundary between "program" and "operating system". The program is indeed compiled; the operating system is not an interpreter, and so the program is compiled for the processor. I appologize I do not understand how that works, and I do not mean to be misinforming people by making statements about things I do not know.
In re-reading my post, it seems I mixed up the concept of creating code that will run on the Vex controller, and creating code that will function on the Vex controller. If you can get code to run on the Vex controller, it may still be a huge struggle to turn on a digital output.
-- Marshal Horn
Unread 05-08-2010, 07:55
A LV diagram is always compiled to some lower level form before execution, and over the years several approaches have been added for reaching targets.
LV desktop and LV RT products compile the diagram directly to machine code for the CPU and OS ABI in use. The code is capable of calling binary library code and this is used for vision, memory management, etc.
LV embedded, also called LV PDA is the product that instead compiles the diagram and generates C source code which can be sent through the embedded C compiler of the HW platform being targeted. The runtime libs are provided as C code.
There are a few products developed for LEGO which compile the diagram and produce a VM bytecode which is then interpreted by the virtual machine running on the brick.
The most recent release of LV desktop and RT (LV 2010), compiles the diagram into LLVM bytecode and the LLVM backend tools are used to produce a more optimized machine code for the target processor.
As stated, at this time, the appropriate way to target the VEX HW would be to use the embedded version. Personally, I don't think it will produce a very satisfying result.
Greg McKaskle
Unread 04-09-2010, 19:58
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
This is what I would try:
1. Write the base program in LabView.
2. Write a translation DLL in C or C++
3. Include the DLL in LabView.
4. Download the program into a memory module
5. Hook up the memory module and run.
Latin:
"Murmure ventus erit parere Tempestatem"
"Noctu teneris vinculis
Nocte illa vincula adimuntur"
pic: Morrella and Lavery... who knows what they are discussing (attention, BILLFRED!! Andy Baker Chit-Chat 10 13-07-2006 16:35
Are these wheels available, anf if not are they ever gonna be? Elgin Clock FIRST Tech Challenge 3 12-11-2005 22:27
Where are they now? Wetzel General Forum 4 20-10-2003 11:23
