Go to Post Stupid rules are still rules. They're not meant to be broken, they're meant to be changed. - Alan Anderson [more]
Unread 03-08-2010, 20:01
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Is the crio powerful enough?
Its been a long time I have posted, nothing got accomplished for my fully autonomous robot idea, just whole bunch of notes and drawing in a notebook. My ideas involve heavy use of trig functions (due to the fact that I took trig in the summer, it inspired me). Now trig functions do take lots of power considering the fact that I might be using at least a dozen of them every cycle, while processing images (mass blob detection), and the locomotion and all that good stuff. Since there is no direct way to monitor memory and processor usage on the crio (or am I just unaware) how can I find out how much it is using? Am I good to go with the Math functions or do I have to make a "Trig chart" or have a onboard processor helping the crio?
If you want to know what I am doing:
I am thinking of using 2 60fps cameras as a stereo vision system and its not very complex on paper either. I think it is the perfect system to use
http://www.cellularfactory.com/lapto...108185&eng=fro
Does that look legit to you guys? Seem pretty "shady" as in Made In China status, do you really think its 60FPS? its pretty cheap though
Unread 03-08-2010, 20:51
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Is the crio powerful enough?
If you are using too much trig processing, then you could always use a lookup table.
You would only need one table for both Sin and Cos because of the identity "sin((PI/2.0) - X) == cos(x)"
You could also cache the results of your equations.
What are you using the trig for?
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 03-08-2010, 21:02
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
The distance of an object purely based on cameras, if you think about it, you will get it very easily, I need diagrams to explain it and might take long time to actually explain though. One phrase: Isosceles triangle with a known base
Unread 03-08-2010, 21:15
Or you could use a polynomial approximation.
You can get a very good approximation to the sine curve from zero to pi/2 (which is all you need to construct the entire curve) with only three multiplies and three adds:
sin(x) ~ -.0017 + x*(1.027 - x*(.0729 + x*(.1116)))
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
if the trig is too much you could attach a TI-83 to the crio, but i doubt the trig will be where the problem is, but in the image processing.
Unread 03-08-2010, 21:50
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
I actually think that doing the trig functions would be faster than doing a lookup table. How long does it take to graph a sine wave on an iBook G4?
Now, what will take a while is the processing of images, ESPECIALLY with disparity maps. You'll probably require an FPGA to get the performance you're looking for. Too bad sbRIOs are in OEM quantities only.
-- Marshal Horn
Unread 03-08-2010, 22:08
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
The Taylor approximation stated above is both extremely accurate and extremely fast. If it is not accurate enough, just add another term. However, I am pretty sure this is how it is done behind the scenes. It doesn't really make that much of a difference. This year, my team did crab drive w/ gyro and I used a ton of trig functions every cycle. The image processing is much much much more processing intense.
Unread 03-08-2010, 22:11
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
So all of you are saying that I should use extra help to process the images, but I doubt there is a legit way to do this though...
Unread 03-08-2010, 22:21
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Before you invest too much in this project, assume a reasonable error in the angles you are able to measure after you try to get both cameras to lock onto a single small point on the object. Additionally assume the object is not perfectly "broadside" to your two cameras. Then compute the range of distance errors that will arise as a consequence of those angular errors.
If you are thinking of using an FRC bot for the base of your triangle, and you are trying get the distances to objects that are scattered around an FRC field, You might be disappointed by the probable size of the distance errors
Or you might be perfectly happy. Just don't overlook the extreme precision required for accurate distance measurements across a reasonably wide field of view.
Blake
Unread 03-08-2010, 22:28
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Lightbulb Re: Is the crio powerful enough?
Blake
I am perfectly fine with "that object is close" "that object is farther" type of thing, I am not making the next mars rover or anything I don't need to be that exact, may be off by a foot or 2 is fine
Unread 03-08-2010, 22:38
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
... off by a foot or 2 is fine
How about a foot or 50? ... There are important non-linearities in the calculations that magnify small measurement errors dramatically.
Unread 03-08-2010, 22:42
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I have no idea what that means, but... Its like the IR Range finders, the voltage output is a curve, gradually evening out and becoming very inaccurate; is this an example of your explanation?
Unread 03-08-2010, 23:12
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I love trig
team 1350 used binocular vision in 2006 somewhat successfully, I wasn't there to get the specifics, but it used 2 CMUcams and trig, and that was with the old IFI rc, assuming there is a target that can be easily picked up at a low resolution, and the servos controlling the cameras are accurate enough (the closer the object, the less acurate they need to be), it should be *relatively simple. Streamlining the rest of the code to free up memory should also help.
Hint, research "boids", it could help with programing how to react to other robots.
Unread 04-08-2010, 00:27
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
It's an secant function where x is your angle and y is your distance.
You can see that after about 60 degrees it gets very inaccurate.
The IR sensor, on the other hand, is exponential decay, which makes a slightly friendlier curve. (Your error at 75% maximum distance is only +-25% of the total range of the IR sensor)
-- Marshal Horn
Unread 04-08-2010, 04:29
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
If this is the only extent you are using this for, I think the simplest method is using an approximating equation based on just one camera.
We've tried this in the past and our greatest error was about 2inches (at a distance of 52 feet). Basically, all you have to do is take a bunch of values of the width or length of the blob versus the the actual measured distance from the camera to the object. Since sight is logarithmic, take a calculator, plug in the datapoints, generate a logarithmic regression and you're good to go.
Edit: Of course, I am speaking in terms of the last 2 games, for which 2 inches would have been a small enough tolerance.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
617 IN THE LIMELIGHT (Close Enough) bsmmoney Chit-Chat 0 08-03-2008 00:01
pic: The gearbox that makes us so powerful keenanmolner Robot Showcase 6 20-02-2007 02:11
The end of mindstorms - no smiley face sad enough Eric Reed FIRST Lego League 20 15-01-2004 16:00
Enough with the bumpers! archiver 2000 2 23-06-2002 22:32
