Go to Post You can admire machines, but you don't really love them... This program has enabled me to make a difference that I believe is good for the future of humans on this planet. - MooreteP [more]
Unread 04-08-2010, 00:27
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Is the crio powerful enough?
Originally Posted by davidthefat View Post
I have no idea what that means, but... Its like the IR Range finders, the voltage output is a curve, gradually evening out and becoming very inaccurate; is this an example of your explanation?
It's an secant function where x is your angle and y is your distance.
You can see that after about 60 degrees it gets very inaccurate.
The IR sensor, on the other hand, is exponential decay, which makes a slightly friendlier curve. (Your error at 75% maximum distance is only +-25% of the total range of the IR sensor)
-- Marshal Horn
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
617 IN THE LIMELIGHT (Close Enough) bsmmoney Chit-Chat 0 08-03-2008 00:01
pic: The gearbox that makes us so powerful keenanmolner Robot Showcase 6 20-02-2007 02:11
The end of mindstorms - no smiley face sad enough Eric Reed FIRST Lego League 20 15-01-2004 16:00
Enough with the bumpers! archiver 2000 2 23-06-2002 22:32
