Go to Post Once we know how magic works it's no longer magic; it becomes science. - Karthik [more]
Unread 03-08-2010, 20:25
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Post custom dashboard questions
So, I've been tinkering around with customizing the dashboard but I've hit a dead-end. I was wondering if anyone knows an easy way to send data back to the robot. Now when I say I want to send data back to the bot, I mean I want to send variables to controls PWM outputs to motors and other actuators.
Is this possible? Or am I missing something simple? Any input is helpful!
Thanks!
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 03-08-2010, 20:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: custom dashboard questions
The dashboard data is a one way pipe from the robot to the computer, no data goes from the dashboard to the robot.
What are you trying to do on the dashboard that you can't implement directly on the cRio?
Unread 03-08-2010, 21:05
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
We were going to try to get some slider values on the dashboard to directly change things like motor speeds, instead of writing or changing one vi to try to fine tune things.
Unread 03-08-2010, 21:29
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
If you use joysticks with throttle's on them you can use them to alter motor speeds. You can have a slider to show the position of the throttle if you need to.
Unread 03-08-2010, 21:33
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
my ZomB dashboard is nice if you are using Java or C++ (You can use LabVIEW too, its just a little more complex because I don't have bindings yet)
http://firstforge.wpi.edu/sf/sfmain/....zombdashboard
go to file releases, Nightly Unstable, 0.6b1 to download
(partial) documentation available under documents, complete guide to the ZomB Dashboard (not complete yet, but enough that you should be able to get it working)
Watchdog.Kill();
Unread 03-08-2010, 22:00
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
Thanks, I have been looking at a thread about this and looks like it'd be something to look at. so we'll try it.
Unread 03-08-2010, 23:02
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Put a control on the VI and run it. Whenever you hit the RUN button in Robot Main, you can adjust the params. in real time (and use the cool graphs and such) with almost no work at all. Just place the control, and connect it on the block diagram. LabVIEW will take care of the rest. When you get it where you want it, right-click and select Data Operations -> Set Data as Default to keep it there. When you build and flash the robot, all of your params. will still be accessible from the code, so you can leave them there and use them for PID tuning and whatnot.
Kettering Motorsports
Unread 04-08-2010, 15:49
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
To expand on what bot190 said, in order for the throttle value to be in the proper range, you'd have to do (throttle+1)/2, as the throttle is from -1 to 1
GSR Dean's List Finalist 2011
Unread 05-08-2010, 14:49
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
thanks for all the great tips guys! and does anyone know how to change the background color of the decorations, like the ones on the dashboard?
Unread 05-08-2010, 15:00
View -> Tools Palette
Unread 05-08-2010, 15:20
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
Thanks
Unread 28-08-2010, 21:57
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
Question Re: custom dashboard questions
I have gotten a custom dashboard made and it opens with the FRC driver station too. Though i haven't gotten to test it with the robot yet, I do have a question, and that is how can i get it to automatically adjust to fit the screen like the default one did?
Unread 28-08-2010, 22:40
From the front panel choose File -> VI Properties
then Category -> Window Run-Time Position
and maybe Window Size depending on what you want to do.
Unread 28-08-2010, 22:58
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
Smile Re: custom dashboard questions
Thanks Mark, your a great help!
Unread 30-08-2010, 00:07
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
How easy would it be to hack a python version of the zomb protocol?
Custom Dashboard? Azores Programming 6 08-04-2010 13:04
So, who has a custom dashboard? Radical Pi Programming 28 15-03-2010 16:36
Custom Dashboard Yppiz FRC Control System 1 17-02-2010 22:45
Custom Dashboard Yppiz Java 1 17-02-2010 12:27
Custom Dashboard writchie FRC Control System 7 02-03-2009 20:21
