Go to Post No such thing as asking too much. There is such a thing as asking too fast, but not too much. - EricH [more]
Unread 06-08-2010, 02:30
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Is the crio powerful enough?
Originally Posted by davidthefat View Post
Thank you for your response, always good posts. Do you have any recommendations on the processors dedicated to process images? So would the cRio would treat the processor as a digital input?
I have only dealt with one type of FPGA, the Xilinx Spartan 3e (250,000 gates).
It can go fast, the board that I have clocks it at 100mhz (and it can go faster).
Acquiring images will take up some resources on the FPGA, but if you are already making your own board (Most FPGAs are ball grid array ics) you could include an ARM (or something similar) processor to grab the image from the camera.
Programming FPGAs is different then a CPU. Everything is in parallel.
For example something simple that can provide weird results is:
    int a = 2, b = 3;
    a = b;
    b = a;
    print("A : " + a);
    print("B : " + b);
If this was executed on a CPU then the results would be as predicted:
"A : 3"
"B : 3"
However, if executed on an FPGA:
"A : 3"
"B : 2"
Since you are the one who is programming the FPGA, you could have it interface to the cRIO in any way that you want. The cRIO has ethernet, serial, SPI, I2C, analog in (this would require digital potentiometers and be slow), and digital IO.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
617 IN THE LIMELIGHT (Close Enough) bsmmoney Chit-Chat 0 08-03-2008 00:01
pic: The gearbox that makes us so powerful keenanmolner Robot Showcase 6 20-02-2007 02:11
The end of mindstorms - no smiley face sad enough Eric Reed FIRST Lego League 20 15-01-2004 16:00
Enough with the bumpers! archiver 2000 2 23-06-2002 22:32
