Go to Post I didn't say it bad English, though. Grammatically, it's perfectly proper. - Greg Ross [more]
Unread 13-08-2010, 08:56
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Enigma Wheel 2
From my experience designing wheels I've found that the most efficient way to make a wheel goes like this:
-Make a sketch with two enclosed sections: the "spider" (a spider is the hub and spokes) and rim cross sections
-Revolve the spider
-Extrude-cut the spider to create 1 spoke
-Make a circular pattern to create all the spokes
-Revolve the rim from the original sketch (use the "share sketch," or similar, option)
-Do any finishing fillets you may need
I've made a couple dozen wheel designs using this method and I've found it to be very robust. There are some flourishes that make it run even smoother, see what you can work out!
pic: Enigma Wheel kgzak Extra Discussion 20 15-08-2010 07:49
Enigma thinker Chit-Chat 0 28-04-2009 09:45
pic: Team 2075 Enigma 2009 Robot Enigma's puzzle Extra Discussion 1 20-02-2009 11:29
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Thank You Enigma Team 356 BBFIRSTCHICK Thanks and/or Congrats 3 31-03-2003 19:06
