Go to Post I'd also like to apologize to any of the teams whose robots we may have broken. - Ginger Power [more]
Unread 15-08-2010, 00:13
BrandonG's Avatar
BrandonG BrandonG is offline
IRC Junkie
FRC #2865 (Roboteknix)
BrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of light
I hope this doesnt make me sound like a noob...
...but how do I control an NXT programmed in labview with the logitech controller? Ive got just a basic program written, and it deploys fine, but it seems that labview isn't detecting the controller... I put an indicator on the output of the joystick and it doesn't change... Ive checked the properties for the controller and it works fine, and Ive made the input a constant to verify that the NXT is working. I cant find anything about it on Google or on here... I'm so lost TT.TT
www.roboteknix.com
Originally Posted by A bum in Atlanta
if you was my sister I'd mug you
If anyone uses IRC, pm me and let me know what networks, I have never heard of anyone in FRC using IRC besides me O_o
Unread 15-08-2010, 00:17
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Re: I hope this doesnt make me sound like a noob...
are you using Labview 2009?, and are you using the driver station for FTC?
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 15-08-2010, 00:31
BrandonG's Avatar
IRC Junkie
Labview 09 yes. No I dont have that... is it needed for this?
www.roboteknix.com
Unread 15-08-2010, 01:03
RookieWookiez's Avatar
RookieWookiez RookieWookiez is offline
Scouting Student Leader
AKA: Dane Potter and Others
FRC #3138 (Innovators)
Team Role: Scout
RookieWookiez is an unknown quantity at this point
I'm sure their are other ways of controlling an NXT brick with a logitech controller, but using an FTC driver station would be the easy way to go. If you have labview installed you can just download the driverstation(found in WPI's FTC programming resources) and run it since it uses the labview runtime engine. I don't know how easily you can get everything up and running with the 2010 driver station (get bluetooth connections established) but i know the 2009 driver station was extremely simple to use, and fairly self explanatory.
Unread 15-08-2010, 01:10
BrandonG's Avatar
IRC Junkie
alright, thanks! I'm trying to get some labview practice in is all.
www.roboteknix.com
Unread 15-08-2010, 01:27
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
If you're accessing the values directly on your computer, you can use the HID devices in the connectivity palette.
This leaves two ways to control the NXT:
Direct control
OR
Communication through Bluetooth inboxes.
If you're not using Windows, then I wish you good luck in making a driver for the joystick with the Visa functions. I haven't looked into the documentation enough to determine the difficulty.
-- Marshal Horn
Unread 15-08-2010, 06:10
BrandonG's Avatar
IRC Junkie
Im trying to find a download for the FTC driver station... I forgot where it was
@kamocat What program are those options in?
www.roboteknix.com
Unread 15-08-2010, 06:57
BrandonG's Avatar
IRC Junkie
hmm apparently the labview package comes with one at C:\Program Files\National Instruments\LabVIEW 2009\examples\FTC Toolkit\FTC Controller Station\FTC Controller Station.exe
Im running that now and its working ^_^ only problem is is that I cant figure out how to get it running on the nxt, and have it also running in labview so that I can probe it and etc.. its 4am now and Ive been messing with this for far too many hours so im going to go to sleep, but let me know if its even possible?
www.roboteknix.com
Unread 15-08-2010, 14:25
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
what values are you wanting to probe? I've always put values on the NXT screen to see them when running code, but I can't remeber if its possible to run the code live.
Unread 15-08-2010, 20:05
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
I'm using LabVIEW 8.6 for FRC. However, I believe they're still available in the LabVIEW 2009 for FTC. Here's a screenshot of where they are in the pallette:
The bluetooth messages and direct control can all be found in the NXT palette. However, it does make a difference whether your current target is the NXT or your computer. (It shows a different palette set for the two.)
-- Marshal Horn
Unread 01-09-2010, 17:58
BrandonG's Avatar
IRC Junkie
Thanks for the help all, but something has killed bluetooth for windows 7 so this is nor longer an issue.
www.roboteknix.com
What do teams hope for in this new challenge? gaby1367 General Forum 0 09-01-2010 08:16
I hope you can help me find this George A. Chit-Chat 3 11-04-2006 16:09
Can i use midis that sound kinda like sounds Salik Syed 3D Animation and Competition 1 22-02-2004 01:26
is this no sound maker,sticks,drums,signs... TiA126 General Forum 6 09-02-2004 22:01
Okay...Someone @ Nats has to be reading this...I hope.. Justin Championship Event 2 11-04-2003 20:06
