Go to Post Who would have thought a triangular robot would fit into a triangular goal :rolleyes: - Wayne Doenges [more]
Unread 15-08-2010, 19:31
ProgramLuke's Avatar
ProgramLuke ProgramLuke is offline
Captain
AKA: Luke
FRC #2169 (KING TeC)
ProgramLuke is an unknown quantity at this point
No Robot Communication
Hello CD,
We are experiencing difficulty in communicating with our robot. We are setting it up for a demonstration at our State Fair. We are working with a Classmate that has been restored via the included Restoration Key flash drive. We have followed the Bench Top tutorial for setting up the router. We are using the WRT160N Linksys router. We have fully updated Labview and the DS. We can run teleop when tethered however when we attempt to connect wirelessly we recieve an message that says to check the communications between the DS Radio and the Controller. We have tried replacing the ethernet cable between the Bridge and Port 1 on the cRio with a ethernet cable that we know to be working.
2012 Inaugural Minnesota State High School League State Champions
2012 Galileo Division Semifinalists
2012 Wisconsin Regional Finalists
2012 Wisconsin Regional Entrepreneurship Award
2012 Lake Superior Regional Chairman's Award
2012 Lake Superior Regional Champion
2012 Lake Superior Innovation in Control
2011 Championship Imagery Award
2011 Championship Archimedes Quarterfinalist
2011 Minnesota 10000 Lakes Finalists
2011 Lake Superior Regional Chairman's Award
2011 Lake Superior Finalists
2010 FTC World Championship Finalist
2010 FTC World Championship Edison Division Champion
2010 Minnesota 10000 Lakes Regional Chairman's Award
2009 Minnesota North Star Regional Chairman's Award
2008 Wisconsin Regional Finalist
2007 Wisconsin Regional Champion
Unread 15-08-2010, 19:36
Re: No Robot Communication
When setting up the bridge, did you make sure to follow the note under step 8 of 2.10.1?
Unread 15-08-2010, 19:42
Captain
AKA: Luke
Our router does not give the to change the 802.11 band. It is the Rookie router.
Unread 15-08-2010, 20:01
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Check to make sure the router and bridge are communicating...the top light on the bridge should be solid (or pretty close, blinking once in a while, but not a steady blink). This is the light with the 3 curved arcs.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 15-08-2010, 20:04
Captain
AKA: Luke
Yes, the router and bridge are communicating.
Unread 15-08-2010, 20:06
rahilm's Avatar
AKA: Rahil Mehta
Try pinging 10.21.69.2 to see if the robot and ds are on the same subnet, etc.
Unread 15-08-2010, 20:51
Captain
AKA: Luke
We have to reset the bridge via the physical reset button and tried to access the bridge via its default IP address: 192.168.1.250 with no success.
Unread 15-08-2010, 21:13
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Have you checked that the cable to the router is tight? The ports on the classmate are known to break (we have to duct-tape our cable in)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 15-08-2010, 21:35
Captain
AKA: Luke
yes we have checked the cables and the ports many times over.
Unread 15-08-2010, 21:37
rahilm's Avatar
AKA: Rahil Mehta
I'm not sure if it's possible, but do you have a second bridge you can test it with?
Also, how long did you wait to recieve communications after turning the robot on? We found that the bootup time on the newer bridge is much longer than the old one.
Unread 15-08-2010, 21:54
Aren Siekmeier's Avatar
on walkabout
Is the wireless bridge still encrypted from competition? You can change this at its http config page by going to 10.21.69.1 (not sure if that's correct) and turning off the WPA encryption if I recall correctly. We had to do this after North Star for a demo we did for the school board.
That this would be your problem seems somewhat unlikely since the reconfiged router and bridge are communicating. It seems however that the bridge is the source of the problem since teleop worked fine when tethered. Finding a second bridge to test would verify this, and then if it works you can just forget about the first one.
I think we are going down to MN Fair tomorrow or Tuesday to ship our bot, so we might be able to check it out if you wanted.
Unread 16-08-2010, 11:16
AKA: Ian Thompson
when you tethered the robot, did you tether directly to the classmate or to the router? If you went to the classmate, try tethering to the router and take the bridge completely out of the equation
Unread 16-08-2010, 15:51
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Luke - If you need any direct help, I'm in the area If it would be easy, I could meet you at our build space in St. Paul on your way to the Fair and get it set up. Just send me a message on here and we'll get something figured out. I've got plenty of experience getting these things working (and not just our teams).
Yes, the rookie router doesn't have the option to change the band... but the gaming adapter bridge (the wireless part that stays on the robot) does. With the rookie router, you need to ensure you have "2.4GHz" set on the bridge, or the two can't connect.
Robot Communication KyleWishnok General Forum 2 17-03-2010 10:09
team 3080 problem no robot communication executionR Technical Discussion 1 20-02-2010 23:32
HELP! Robot Communication RedHeadRobotics Technical Discussion 4 12-02-2010 00:49
Robot to robot communication John Gutmann Programming 19 07-12-2005 08:18
mini made robot communication John Gutmann Electrical 1 19-07-2005 23:16
