Go to Post Alright, looks like we've sidetracked into "Off-Topic Land", an area I know I have to visit every so often but I am always happy to leave. - Jessica Boucher [more]
Unread 18-08-2010, 08:11
Re: frequency range of AC clamp current meters
Marshal,
The clamp type meters I have used in the past have a max frequency of about 400Hz. That is OK for the 150 Hz switching frequency of the Victor. The Jaguar is 15 kHz and although it may show some current on the meter, it will not be accurate and will show considerably less than actual. The type of current transformer Eric linked to also has a frequency response characteristic that will play into the readings. The sheet does not spec the response but I am guessing it is optimized for 60 Hz.
Clamp On DC Current Meter kramarczyk Electrical 11 04-01-2010 10:51
Dashboard Analog Meters and GPIO? Geek_Girl Programming 1 17-12-2008 09:50
Clamp Race kE7JLM General Forum 4 05-02-2008 18:43
Timing Belt Clamp shorton Technical Discussion 10 18-07-2006 22:50
D.C. Clamp on Ammeter archiver 2000 2 23-06-2002 23:27
