Go to Post Change your process to change your product. - Justin Montois [more]
Unread 18-08-2010, 19:29
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: pic: CAD exercise - 1640 Pivot Assembly with cut-away view of Pivot Module
I am very surprised that you did not have trouble with the cantilevered side-load on the Denso motor shaft. The worm gear in that motor is a plastic gear captured only by the thin sheetmetal lid on the housing, and is not designed for any side-load whatsoever. You might want to consider supporting the end of that sprocket if you can. We have found that a 5/8" OD ball bearing fits nicely into the center hole of the plastic Denso adapter to provide end support.
I very much like the chain reductions and overall design of your module. Very similar to our own.
pic: 1640 Pivot Module Clem1640 Extra Discussion 11 05-08-2010 00:47
pic: 2228 Cougar cut on to sheetmetal (CAD) jamie_1930 Extra Discussion 11 09-05-2010 19:29
pic: 1640's 2010 Pivot Assembly Gdeaver Extra Discussion 8 10-02-2010 20:11
pic: Swerve Module Concept (View 2) Dave McLaughlin Extra Discussion 5 17-06-2009 00:15
pic: Swerve Module Concept (View 1) Dave McLaughlin Extra Discussion 15 16-06-2009 22:36
