Go to Post When you are able to get inside their heads, you will either... or.. B) Learn way to much, and end up running away screaming. - Either way, it'll be a learning experience. - Elgin Clock [more]
Unread 19-08-2010, 11:05
Gdeaver Gdeaver is offline
FRC #1640
Re: pic: CAD exercise - 1640 Pivot Assembly with cut-away view of Pivot Module
There is a thread on the Jag and Denso problem.
http://www.chiefdelphi.com/forums/sh...ad.php?t=83973
We have not responded to this thread since removing the locking pins. Even with the locking pins removed, we experienced random Denso shut down. For IRI we swapped out the jags for victors and the problem has disappeared. The window motors are great without the locking pins and victors. We have no hard data to help with why the Denso's overheat while under very light load with the jags. I think it has something to do with the high switching frequency of the jags interacting with the PTC causing it to self heat. I would like to see First allow the removal of the locking pins. Its easy and improves the performance of the motors. However, The bypassing or removing the PTC is much more questionable. It's an actual modification of the motor. So if you use the window motors, use victors.
pic: 1640 Pivot Module Clem1640 Extra Discussion 11 05-08-2010 00:47
pic: 2228 Cougar cut on to sheetmetal (CAD) jamie_1930 Extra Discussion 11 09-05-2010 19:29
pic: 1640's 2010 Pivot Assembly Gdeaver Extra Discussion 8 10-02-2010 20:11
pic: Swerve Module Concept (View 2) Dave McLaughlin Extra Discussion 5 17-06-2009 00:15
pic: Swerve Module Concept (View 1) Dave McLaughlin Extra Discussion 15 16-06-2009 22:36
