Go to Post You can either spend lots of energy complaining about it and whining or you can try to figure out how to make a positive experience from the whole thing. - dlavery [more]
Unread 22-08-2010, 00:53
Chris is me's Avatar
AKA: Pinecone
Re: User Interface - Drivetrain Controls
Originally Posted by kamocat View Post
If the joysticks don't re-center perfectly when you let go, there is slight movement instead of the "stopped" you might want. (usually less than 1% full speed) This is because the "deadband" to deal with this is actually on the motor controller, not the joystick, and PID is a method of ensuring that the motors do what you tell them to.
The "deadband" is not a speed controller side problem... The speed controller deadband actually increases the number of possible PWM inputs that get you zero motion. Any "moving when centered" problem is on the joystick side. It's particularly notable on Xbox 360 controllers.
Regardless deadband is easy to fix with simple scaling functions, you don't even need PID.
pic: Team 241: User Interface Dantvman27 Extra Discussion 1 21-02-2007 13:12
is the 2004 user interface compatible with the 05 RC? wildabyss Control System 5 22-02-2005 05:28
Using non joystick controls with Operator Interface (Hacking Various Controllers) Astronouth7303 Control System 58 02-02-2005 15:56
[FVG]: User Interface Mike Ciance FIRST-related Organizations 15 25-07-2004 14:30
GUI (graphical user interface) nzj1 Programming 1 17-01-2003 22:47
