Go to Post Based on EXTENSIVE analysis of this image, I have concluded that we will have to use wires on our robots. I am certain of it. - theCADguy [more]
Unread 18-08-2010, 00:58
paper: CAN Jaguar Speed Control with Current Limit
Thread created automatically to discuss a document in CD-Media.
CAN Jaguar Speed Control with Current Limit by Ether
Unread 18-08-2010, 01:07
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: paper: CAN Jaguar Speed Control with Current Limit
It seems to me that there wouldn't be enough bandwidth between the cRIO and the jaguars to implement this effectively, as I believe [kamocat]'s testing says roundtrip communication times are in the 10s or 100s of milliseconds, and current spikes will potentially be shorter than that.
While it may help against motors sitting in stall for long periods of time, I'm not certain if this will retain all the desired points of current control mode. Could definitely be worth testing, however.
--Ryan
FRC 766, 2015-, Mentor
Unread 21-08-2010, 11:58
Thanks for your comments Ryan.
If the concern is the circuit breaker in the Jag, take a look at the Jag in current-control mode with cRIO controlling speed.
If the concern is motor damage due to overheating, the thermal cutoff approach might provide some protection.
If the concern is traction control, using the Jag in speed-control mode and providing a current limit in the cRIO might be the best thing to try.
Unread 22-08-2010, 00:59
RyanCahoon's Avatar
I guess my comments were mostly because I hadn't seen the usage cases.
Help with CAN bus closed-loop speed control RoboGuy Programming 16 14-04-2010 12:34
Gray Jaguar CAN closed-loop speed control Ether CAN 6 13-04-2010 23:10
CAN Jaguar Enable Control .vi Initial Encoder Position TonyP CAN 0 26-02-2010 19:23
jaguar speed control of mecanum wheels Ether Motors 7 05-02-2010 13:02
Can I control a victor/jaguar with an RC receiver Bruceb Electrical 3 30-12-2008 10:50
