Go to Post This thread is just as lethal as any design your own game thread. - Schnabel [more]
Unread 20-08-2010, 19:04
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
How to work with pneumatics
Hey I'm starting to do pneumatics only I dont know how to start. How would you start to do something simple like turn the compressor on. We are using Windriver by the way. The compressor is connected to Digital sidecar relay 8 also.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 20-08-2010, 19:14
Re: How to work with pneumatics
Have you looked at the compressor class?
Unread 20-08-2010, 19:20
John Rangel
How do we use this compressor class?
2014-? Mentor
Unread 20-08-2010, 22:50
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Compressor *compressor;
Contructor() {
compressor = new Compressor(PRESSURE_SWITCH_CHANNEL, RELAY_CHANNEL);
compressor->Start();
replace PRESSURE_SWITCH_CHANNEL and RELAY_CHANNEL of course
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 22-08-2010, 12:07
DonRotolo's Avatar
Back to humble
FRC #0832
The short version is that there are classes (named objects) in the software packages we have been given. You just plug in the specifics (such as 'channel 8 of sidecar 0') and it works. I'm not a programmer, so I can't explain how it works. Magic, maybe. But it's pretty easy.
Turning the compressor on an off is only the start, of course. You turn it on while the pressure switch is "closed" and then turn it off when the switch is "open". The only other major thing you need to do is 'turn on this solenoid valve' when 'this' (usually a joystick button press) happens. You usually toggle the valve on or off depending on what condition it had last.
Unread 22-08-2010, 23:46
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
What? I just made a solenoid object and literally just turned on or off the solenoid that was controlling the compressor, it worked great.
Unread 23-08-2010, 02:06
It "works", but it's not in accordance with the robot rules of the past two years. The compressor must be controlled based on the feedback from the pressure switch.
Unread 31-08-2010, 19:22
John Rangel
Originally Posted by Radical Pi View Post
Contructor() {
How do we put this piece of code on our code. We just have the simple template.
2014-? Mentor
Unread 31-08-2010, 20:19
John Rangel
Never mind, got the compressor to start but now we need to get the compressor to stop. How do you make it stop at 60 psi?
2014-? Mentor
Unread 31-08-2010, 22:17
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
You can't do this with whats in the KOP. Your pneumatics system should have a pressure switch inline with it. The pressure switch from the programs point of view, returns 1 when the pressure is less than 90 then returns 0 when its greater than 115. If i remember correctly. What the compressor class does is takes the channel for the pressure switch and a channel for the relay for the compressor itself. Then it turns the compressor on when the pressure switch returns a 1 and shuts it off when the pressure switch returns 0.
To turn the compressor off when it reaches a different PSI, you either need a pressure switch that changes state at 60 PSI or you need a Pressure Transducer, which applies resistance depending on the pressure.
Unread 31-08-2010, 22:23
AKA: Ian Thompson
you have compressor.Start() in the OperatorControl loop. it should be in the initializer (where you have GetWatchdog().SetExpiiration(0.1), so your code becomes
	RobotDemo(void):
		myRobot(3, 4),
		myRobot2(2, 1),
		myRobot3(5, 6),
		stick(1),
		stick2(2),
		stick3(3),
		compressor(1, 8)
		compressor.Start();
		GetWatchdog().SetExpiration(0.1);
Assuming you have a pressure switch hooked up to GPIO port 1 your compressor should stop at 120 psi
Also, why do you have 2 different robotDrives running with the same inputs? You can list 4 jaguars in the initializer of a single robotDrive and it will output to two motors per side.
Half of pneumatics doesn't work Red Mage Pneumatics 12 12-02-2009 09:52
No pneumatics work help nevereverregret Pneumatics 3 12-02-2009 08:14
How to wire pneumatics LuckyLotto2487 Electrical 9 11-02-2009 14:35
Ultrasonics: Will it work and how to make it work DavidB Electrical 2 17-01-2009 16:27
How long to get Pneumatics? sanddrag Pneumatics 3 31-01-2005 01:18
