Go to Post at what point does gracious professionalism turn into cut throat competition? - aepstein [more]
Unread 24-08-2010, 12:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Need help with powder room.
I am going to redo my powder room downstairs in FIRST style. I have lots of mementos from past robots and events for the decorations and I figured I would make the vanity out of KOP frame or 8020.
What I need is a good idea for the sink. I was figuring an aluminum top with a regular glass vessel but was wondering if my fellow CD's could come up with a better idea.
Also any other ideas for decorations or fixtures would be welcomed.
Thanks
Unread 24-08-2010, 13:05
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Need help with powder room.
I would incorporate the lazy susan into the medicine cabinet or storage somehow. Of course it needs to be motorized and have limit switches to control it.
A CIM powered toilet paper dispenser would also be a hoot.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 24-08-2010, 13:08
kstl99's Avatar
kstl99 kstl99 is offline
AKA: Kevin
FRC #1922 (Oz-Ram)
kstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond repute
Send a message via AIM to kstl99
This should be a great thread! Is this the first bathroom related thread on CD?
My first thought is diamondplate around the sink.
Hopefully no 120 pound weight limit.
How about a sensor to trigger the "start of a match" signal when you go in and a signal for when you have 20 seconds before you must get out?
Sorry for the bathroom humor.
Unread 24-08-2010, 13:33
Chris is me's Avatar
AKA: Pinecone
I bet if you're clever enough, you could fit a Globe motor inside your toilet paper roll. Put a small wheel on the output shaft and friction drive the whole thing to spin toilet paper neatly out on command.
Unread 24-08-2010, 14:25
DinerKid's Avatar
DinerKid DinerKid is offline
AKA: Zac
FRC #1768 (Nashoba Robotics)
DinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of light
It would be really cool if you incorporated all of the above ideas but controlled them with an actual robot control system mounted on the wall or something and used push buttons to control every mechanism. This could get really pricey really fast... I like it.
~DK
Unread 24-08-2010, 14:31
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Clearly you need automatic faucets - you know, a motion sensor that triggers a robotic arm to turn the water on and off for you
Unread 24-08-2010, 14:33
The first person to say "water game" gets negative reputation.
Hmm? What? Oh.
Oops.
Never mind.
Unread 24-08-2010, 14:36
Joining the 900 Meme Team
FRC #0079
Oh.
Oops.
Never mind.
Isn't that what children play when they try to flush a tie down the toilet?
The toilet needs to have the vision target on it...
Perhaps the sink could have something to do with the 2003 bins. or the 2005 tetras?
Unread 24-08-2010, 14:39
BJC's Avatar
BJC BJC is online now
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
How about a big picture of Dean's face where the mirror would be.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 24-08-2010, 14:40
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Orbit ball lamps anyone?
You could replace one of those single handled faucets with a KOP joystick.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 24-08-2010, 14:43
AKA: Pinecone
A really simple but probably decent idea: Replace the current handles with shafts with gears on the end, geared to another shaft with a handle on it. Reduction optional.
Unread 24-08-2010, 14:52
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
I second the diamond plate sink and motorized toilet paper. Get a cRio, mount it in the medicine cabinet, and run a bunch or stuff off it. Automated lights, auto toilet paper, its all possible!!!!
WPI Robotics Engineering & Mechanical Engineering Class of 15
iRobot Mechanical Engineering Intern
Unread 24-08-2010, 16:21
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
A 2002-2003 rotating light with interchangeable red and blue caps would be a very nice light fixture.
Unread 24-08-2010, 16:26
AKA: Pinecone
Or use an IFI control system and you won't have to wait 2 minutes to use your bathroom
Unread 24-08-2010, 16:47
kstl99's Avatar
AKA: Kevin
FRC #1922 (Oz-Ram)
Make it wireless and you can really surprise people from the other room.
Need Help with SQL Tom Bottiglieri Website Design/Showcase 10 01-03-2004 15:49
need help with the ir tinderfitles Programming 3 03-02-2004 15:31
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Need help with C++ Tton Programming 7 04-11-2003 19:15
Need Help With Textures!! archiver 2001 1 23-06-2002 23:36
