Go to Post Programming isn't that hard once you get the hang of it. It has a steep learning curve like math. One day your trying to figure out 1 1, then the next day they throw x and y at you. Once you understand what x and y represent and learn to think in terms of functions, it's as easy as pi. - sciguy125 [more]
Unread 25-08-2010, 20:48
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
LIDAR simulation
I was investigating what the world looks like with non-contact distance sensors (SONAR, LIDAR, IR), so I made a simulation.
This is intended to run on your computer. Be prepared to create a sample map of obstacles with an image editor, and show context help to view the descriptions.
(The code itself is not heavily documented (no VI descriptions), but the user interface should be)
Happy simulating!
PS.
You could use this for testing algorithms for autonomous robot navigation.
-- Marshal Horn
Unread 26-08-2010, 08:00
Re: LIDAR simulation
Very good idea with the visualization. These space bending transforms are often hard to visualize at first, but with a few samples, it is amazing how your head can then generalize and learn how to see the world as a ...
If you are looking to improve the UI, being able to see both the picture and graph at the same time would be a nice thing. That would allow you to scan the picture in your head and compare your intuition with the graph . For an even better demonstration, slow it down and animate a sweep bar around the picture and graph the mapped points over say four seconds.
Also, the double click is an OK trigger, but I'd suggest treating it like a map at the mall. Place a colored dot on it (you are here). Let the use click or drag to move the dot. Put in a default map with interesting stuff and always have something in the graph, and I think this makes a nice demo.
Good job.
Greg McKaskle
Gear Simulation Software dtengineering Math and Science 3 09-05-2011 16:53
Excel Simulation Tknee Rules/Strategy 1 10-03-2010 01:02
FIRST Overdrive Simulation lachoneus8 IT / Communications 10 27-01-2009 21:49
Software Simulation JimS Programming 4 29-03-2005 07:29
Computer Simulation Seared Ice Technical Discussion 1 07-02-2005 16:48
