Go to Post No, I dont mix robots and girls. - Tom Bottiglieri [more]
Unread 25-08-2010, 22:18
Aren_Hill's Avatar
Build Nifty Things
Re: Winnovation Midwest Coast Drive
Originally Posted by JesseK View Post
1/32" polycarb could be riveted over the holes to prevent debris from cutting the belts. The obvious tradeoff is increased time to repair.
Velcro! or the preferred 3M dual lock
A guy who likes robots.
Unread 26-08-2010, 11:36
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Looks great, very well put-together!
Just a thought about the belt-wear testing: you'll probably want full-grip wheels to test how quickly the belts wear out, otherwise you won't really be putting the belts under full load.
Unread 26-08-2010, 14:44
RookieWookiez's Avatar
RookieWookiez RookieWookiez is offline
Scouting Student Leader
AKA: Dane Potter and Others
FRC #3138 (Innovators)
Team Role: Scout
RookieWookiez is an unknown quantity at this point
Are you using 4 or 6 inch wheels?
Unread 26-08-2010, 15:37
Carrington's Avatar
Carrington Carrington is offline
AKA: Carrington
FRC #1625 (Winnovation)
Carrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant future
We are using SBR rough top on the wheels.
They are 4 1/2 inch wheels.
Unread 26-08-2010, 15:51
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Ah, very good, though there isn't any tread in the pictures.
Unread 26-08-2010, 16:02
Carrington's Avatar
AKA: Carrington
Yeah we just put the tread on the wheels yesterday.
Unread 26-08-2010, 16:16
Team Role: Scout
[quote=TheLoneAsian;972560)
They are 4 1/2 inch wheels.[/QUOTE]
Ok that's an odd size, why not use bigger wheels where u will get more speed out of ur wheels. Do u no how much the wheels weight?
Unread 26-08-2010, 16:27
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Speed & Torque are a tradeoff in electric motors. 4 1/2" wheels may be appropriate for 1625's general drive train speed/torque targets, and easy adjustments can be made by changing the pullies in the gearbox.
GitHub
Unread 26-08-2010, 16:35
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Also, smaller wheels let the wheels reach a higher speed with a smaller gear ratio, which is (in theory) more efficient.
Theory is a nice place, I'd like to go there one day.
Unread 26-08-2010, 16:51
Chris is me's Avatar
AKA: Pinecone
More importantly, smaller wheels means you spend less weight on wheels AND gears, since you have less of a reduction. Luckily weight isn't that theoretical.
Unread 26-08-2010, 17:04
Carrington's Avatar
AKA: Carrington
Our wheels weigh approximately 3/8 of a pound, but they could probably be lighter. We used these wheels because they were easy for us to make and cost effective. If we built this drivetrain in an actual build season we would probably use even smaller wheels made out of aluminum.
Unread 26-08-2010, 22:25
NotSoSiniSter NotSoSiniSter is offline
NotSoSiniSter is on a distinguished road
Great Design We've been thinking about doing some gear shifting too. Having the extra power would be great
Hopefully, next years field wont have a terrain element that cant be avoided. :/ Clearance is always annoying.
Unread 27-08-2010, 08:10
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Absolutely beautiful design and I love the idea of keeping the belts internal. We used belts the past season and they are ridiculously robust as long as you make sure they're tensioned correctly.
My question is did you broach the plastic wheels for direct drive or is there a hub in them?
Mentor 2415
Unread 27-08-2010, 13:25
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Not to mention that small wheels require less material, less tread to tread them, and often less machining time, so they're less expensive to make. (Cost isn't theoretical either )
Oh, and they look cool.
-Dustin Benedict
Unread 27-08-2010, 13:39
That looks really pretty, but I'm a total newb when it comes to belt drives.
Can you explain it to me in a way that will allow me to teach it to a team later?
Specifically:
Why belt vs chain?
How do you tension it?
Any quick rules-of-thumb I should know about?
Or better yet, how do I tell if a belt system is good? Often, knowing if the result is good is almost as useful as knowing how to get a good result. {P=NP?}
pic: 2010 Lake-Coast drive gorrilla Extra Discussion 12 16-02-2010 11:54
West coast drive (6wheel) question Bruceb Technical Discussion 9 09-01-2010 09:34
pic: Winnovation Drive Team hillale Extra Discussion 6 07-03-2009 23:18
pic: West Coast Drive: Spokane Style CraigHickman Extra Discussion 31 14-12-2008 20:02
East Coast, West Coast, and Midwest FIRST Aaron Lussier General Forum 52 04-08-2003 01:52
