Go to Post I'm absolutely certain that kids prefer scoring points to not scoring points - AdamHeard [more]
Unread 25-08-2010, 22:34
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Question How To Implement Axis Camera In Iterative Robot
Hi,
I am trying to implement the AxisCamera class into our Iterative Robot method, but unfortunately, the AixsCamera class has a difficult time initializing properly. We currently have:
AxisCamera* camera;
camera = &AxisCamera::GetInstance();
Is this how we can initialize it besides:
AxisCamera &camera = AxisCamera::GetInstance();
I am pretty novice to all this allocation and stuff, so I would love to have any sort of feedback!
Thanks!
-Masoug
JabbaScript
Unread 26-08-2010, 10:36
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: How To Implement Axis Camera In Iterative Robot
Do you have it just like that? or do you have the variable declared up top?
class yourRobotClass: public iterativebot
AxisCamera &camera;//declare here
public:
yourRobotClass()://constructor
camera(AxisCamera::GetInstance())//init here
Watchdog.Kill();
Unread 26-08-2010, 13:03
masoug's Avatar
Food Consumer
FRC #0114
Thanks for the quick reply!
Um, we had it like that.
isn't that the same as
 AxisCamera* camera;
Sorry, I am not that familiar with C++ pointers and addresses...
Can you also explain your code a little more clearly? E.G.
 camera(AxisCamera::GetInstance());
isn't the constructor private?
Thanks!
-Masoug
JabbaScript
Unread 26-08-2010, 16:51
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
constructors are public (in every program I've seen)
The & makes the variable camera a reference. A reference is similar to a pointer, however once it it set it cannot be changed, and it acts like a non-pointer variable after being set (Use the . operator to access funtions instead of -> )
The camera(AxisCamera::GetInstance()); sets the camera reference to the global AxisCamera object. From that point on if you want to do something like get an image the code is camera.GetImage(imageVar);
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 27-08-2010, 15:40
byteit101's Avatar
not always, but at least one is usually available: the copy constructor (which is used here)
.net has quite a few classes that don't have public constructors (like Graphics)
Watchdog.Kill();
Unread 28-08-2010, 02:24
masoug's Avatar
Food Consumer
FRC #0114
Thanks!
Now it compiles, but I have a few questions:
what does
function() : another_thing(){}
really do? Is it like a class, where function() "inherits" another_thing()?
How does that exactly work?
-Masoug
JabbaScript
Unread 28-08-2010, 11:43
AKA: Ian Thompson
No inheritance here. another_thing is a variable defined somewhere else. It gets set with the value in the parentheses when the function is called.
Unread 28-08-2010, 17:12
masoug's Avatar
Food Consumer
FRC #0114
Question Re: How To Implement Axis Camera In Iterative Robot
So then how is that different than
I heard about "initialization list", but what/why is this a case to use it? What about AxisCamera class that it has to bee initialized as a reference?
Thanks!
-Masoug
JabbaScript
Unread 29-08-2010, 20:51
byteit101's Avatar
Thanks!
-Masoug
references can only point to one thing in there life, and you must set it at the very beginning. If you'd used a pointer, you could do that, since pointers can point to many things in their life
The GetInstance returns a reference, so it has to be a reference or a pointer
Watchdog.Kill();
Unread 01-09-2010, 20:25
masoug's Avatar
Food Consumer
FRC #0114
We still have the same problem, when I implement it in the method:
public:
the robot code will not work, complaining that:
Relocation value does not fit in 24 bits.
is there another problem that come along with the camera class?
Thanks!
-Masoug
JabbaScript
Unread 01-09-2010, 22:04
A search of the forums for that error message yields a possibly relevant thread.
Unread 08-09-2010, 21:26
masoug's Avatar
Food Consumer
FRC #0114
I checked and "-mlongcall" was already there and the cRIO still complains about "Relocation value does not fit in 24 bits."
Is there any other thing we can do?
Thanks!
-Masoug
JabbaScript
Iterative Robot Template? jalburty C/C++ 4 08-04-2011 13:57
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Iterative Robot demo mandrews281 C/C++ 0 21-03-2009 15:45
Dashboard and Robot main with Axis camera Team2883 General Forum 9 10-01-2009 07:35
Please Help, Don't Know How to Implement Tank Drive in LabView CVassos NI LabVIEW 5 24-12-2008 16:55
