Go to Post STICK WITH WHAT WORKS FOR YOU!!! - Will Hanashiro [more]
Unread 30-08-2010, 08:32
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Excessive spamming on CD
I am sure many people have noticed it. I just got this PM today:
Build a CNC machine and manufacture any custom part your heart desires, check this out!
CNC router applications include-
Sign making - wood, plastic, foam, vinyl, and electronic LED signs.
CNC wood projects - pictures, carving, engraving, parts.
Cool projects - science projects, school projects, DIY projects, and club projects.
Multi functional - 3D digitizer, dispensing, gluing, automated testing, and additive prototyping.
PCB milling, PCB engraving or PCB routing of circuit boards. PCB drilling and PCB testing.
CNC robot and robotics projects.
Arts and crafts, cut vinyl, paper, wood, plastic, 3D carving and engraving.
Invent - build prototypes for inventing and experimenting.
http://shop.ebay.com/sashasolo/m.htm...&_trksid=p4340
Enjoy!
I seems to me that there needs to be a more rigorous system to ensure that new users aren't spammers/spam bots. The amount of spam posts/threads is much higher on CD than any other forum I frequent.
Unread 30-08-2010, 10:26
Re: Excessive spamming on CD
Spammers are getting more and more creative.
Moderators (and vBulletin) have a number of means to deal with them; however, spammers like to get around those.
There was a suggestion that the moderators re-distribute themselves to help, but even that might not work with PM spam.
I'd go with a minimum post limit for PM sending (say, 1-5 posts before PMs), kind of like with the rep system
Mods, can you get to user Daisy22, fast?
Unread 30-08-2010, 11:05
Chris is me's Avatar
AKA: Pinecone
I personally don't think restricting PMs to when you've made x posts is particularly helpful. I've gotten PMs from people with zero posts who had nothing to say on the forums but wanted to know something about my team or robot.
Unread 30-08-2010, 12:02
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I think the restriction would simply force the spammers to make (for example) posts of spam before the PM spam. However, a minimum post threshold can determine the variables for the folloing algorithm, much like fraud detection sensitivity increases for a credit profile when a credit card # is stolen:
For low post-count users, perhaps delay all PM's by [N] seconds to see if multiple PMs from the same user are being sent out. For each new PM sent before the delay expires, increase the delay of all PM's by that user by [N] more seconds. Once a quantity [X] of PM's are sent out by a single user before the delay [N] expires, delay them indefinitely until a mod can visually review them. For PM's sent to multiple users from a 'new' account, put a threshold [Y] of review: e.g. if sent to more than 5 users, it will be delayed until reviewed (4 users would still be delayed via the algorithm described above). Put a disclaimer in the PM process that PM's may be delayed and reviewed if sent en mass.
As a user increases post count, decrease the sensitivity (lower the delays, increase the user threshold) of the variables X, Y and N. In that way, current known accounts (e.g. EricH) are allowed to send multiple [assumed legititmate] PM's without scrutiny while also allowing new legitimate users to do the same once a certain amount of 'trust' is built.
Perhaps it could be a vB feature in the future?
The other metric that could be used is reputation; typically those with 50+ posts have received some sort of reputation, either positive, neutral, or negative (though the actual magnitude of rep shouldn't play into the variables since the concept is just a user authentication algorithm).
GitHub
Unread 30-08-2010, 15:54
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
and user Alexiss
Perhaps there just needs to be a 'report' button for PM's like there is with posts. I don't see why they couldn't be dropped into the same queue from response by moderators.
Mark
Brick walls are for other people. - Randy Pausch
Unread 30-08-2010, 16:05
Both Daisy22 and Alexiss have been disabled, along with 3 others. There may be more that we missed, so post the username if you got one.
Unread 30-08-2010, 16:25
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
I got one of these messages today from the user "Juliz".
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 30-08-2010, 19:24
The Cyborg's Avatar
The Cyborg The Cyborg is offline
That Awkward One
AKA: Mary Soltis
FRC #0051 (Wings of Fire)
The Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant future
Add user Daniel3 to the list.
Unread 30-08-2010, 19:41
Onward through the fog.
Well, Klarance wants me to build a CNC machine and manufacture parts to my heart's content.
Obviously, this 'person' has no idea what I am capable of.
Jane
~ Helen Keller
(1880-1968)
Unread 30-08-2010, 21:54
With a twist--if a user gets reported enough times by enough different people, their PM sending privileges automagically get shut down long enough for a moderator to review the reports and either allow the PMs or block the user's PM/site access. I don't know how hard that would be to implement, though.
Unread 30-08-2010, 22:21
kramarczyk's Avatar
I'm thinking that if the message is offensive enough that I am going to report them to the board mods, then once is enough. A PM is a bit more personal than a post. As for false flags (not spam), probably one or both users need to be brought up to date on what is acceptable on this board.
Mark
Unread 30-08-2010, 23:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Venessa sent me the spam pm.
Unread 30-08-2010, 23:43
Jared Russell's Avatar
Taking a year (mostly) off
Add Shanel.
Unread 30-08-2010, 23:49
MrForbes's Avatar
AKA: Jim
The member list does not appear to have a "date joined" sort...if so, you'd probably find a lot of spammers among the newest members?
Unread 31-08-2010, 12:23
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Dorisz1 doesn't know how small my garage is.
Hi!
The "fix-it window"? Jolly good show -or- is 23 cups of coffee/day really excessive? erniep General Forum 17 14-01-2005 12:06
