Go to Post Semi-colon cancer -- the disease received after spending too much time writing lines of programming code - nehalita [more]
Unread 30-08-2010, 17:10
team3329 team3329 is offline
None #3329
team3329 is an unknown quantity at this point
Software HELP!!!
Well... we were going fine this year using labview and all of the NX Intruments software. At competition in may we were given the recent uptdates for Labview. When we tried running the updates something went wrong and our labview crashed and we had to remove EVERYTHING! So we still have the discs with the software, but the laptop that we are running things from has no disk drives (only the hard drive) and the biggest problem is that we have no memory sticks to transfer the programs onto. If any one has a way that we can get just Labview back that would be great! thanks.
Unread 30-08-2010, 17:32
Re: Software HELP!!!
Can you borrow a USB drive? Copy the disks on another machine to the USB drive then plug the USB drive into your laptop.
Does the laptop have a network card? Copy the disks to a machine on a network, then connect your laptop to the network.
Unread 30-08-2010, 21:09
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
You can also FTP directly from one computer to another.
This may take a while, since you're transferring 6 GB.
-- Marshal Horn
SOFTWARE PROBLEM!!!! PLEASE HELP!!! RedHeadRobotics Programming 28 21-02-2010 16:07
FRC Software Help henrylu33 Programming 2 06-05-2009 21:16
Event Match Software Help Kims Robot Technical Discussion 1 27-10-2006 02:04
Software Help AzNDynasty FIRST Lego League 1 25-10-2005 17:19
Help me test scoring software? devicenull FIRST Lego League 4 06-10-2004 21:11
