Go to Post The discussion and helpfulness that goes on within this website is a great example of gracious professionalism. - andy.vangessel [more]
Unread 27-08-2010, 23:09
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Im doing something wrong here (python)
I'm working on a scouting gui and framework for my team. I have the following files (in a spoiler):
[spoiler]
teamLib.py:
#!/usr/bin/python
import os
toCommit = list()
class team:
    Its a object to hold team data
    def __init__(self, name = "", number = 0, robotName = "", robotType = 0):
        self.name = name
        self.number = number
        self.robotName = robotName
        self.robotType = robotType
def newTeam(name, number, robotName, robotType):
    Wrote this before i found out about constructors, does the same thing as team.__init__()
    temp = team()
    temp.number = number
    temp.name = name
    temp.robotName = robotName
    temp.robotType = robotType
    return temp
def teamFromDict(theDict):
    Returns a team object based on a dictionary argument
    return team(
        theDict["name"],
        theDict["number"],
        theDict["robotName"],
        theDict["robotType"]
def saveTeam(team_obj):
    Appends the team object to the toCommit List
    config = {}
    config["name"] = team_obj.name
    config["teamNumber"] = team_obj.number
    config["robotName"] = team_obj.robotName
    config["robotType"] = team_obj.robotType
    toCommit.append(config)
#    f = open("./Scouting/robot", "w+")
#    f.write(repr(config))
#    f.close()
def read():
    Opens the config file, returns the superDict
    try:
        f = open("./Scouting/robot", 'rt')
        try:
            content = f.read()
            config = eval(content)
            f.close()
            toCommit.insert(999,config)
        except:
            print "cannot read file"
    except:
        print "cannot open file"
def commit():
    Writes the team values to the config file in a listed dict
    f.write(repr(toCommit))
    f.close()
    clearList(toCommit)
def clearList(lists):
    A clever hack to kill a list
    while True:
        try:
            lists.pop()
        except:
            break
def interpretList(lists, value):
    Give it the list you want, and the position of the team, and it will return a team object with the dict data
    return teamFromDict(lists[value])
def countListElements(lists):
    i = 0
    while True:
        try:
            lists[i]
        except:
            break
        i = i + 1
    return i
cmdlinehelpers.py:
import teamLib
numberOfTeamsInList = teamLib.countListElements(teamLib.toCommit)
def addTeam():
	teamLib.saveTeam(
		teamLib.team(
			raw_input("Team Name: "),
			input("Team Number: "),
			raw_input("Robot Name: "),
			input("Robot Type: ")
	print "Saved to list"
def showTeam():
	print numberOfTeamsInList
	temp = numberOfTeamsInList
	request = input("choose a number")
	prettyify(teamLib.interpretList(teamLib.toCommit, request))
def prettyify(teamObject):
	print "Team Name: %d" %teamObject.name
	print "Team Number: %d" %teamObject.number
	print "Robot Name: %d" %teamOcject.robotName
and, finally, cmdLineTest.py:
#!/usr/bin/python
import teamLib, cmdlinehelpers
teamLib.read()
alive = True
print "There are the following number of teams in the list"
print "\nPlease enter your command:"
while alive:
	request = raw_input("$> ")
	if request == "show":
		cmdlinehelpers.showTeam()
	if request == "add":
		cmdlinehelpers.addTeam()
	if request == "help":
		print "Commands are: \n\nshow, add, save, load, help, quit"
	if request == "save":
		teamLib.commit()
		teamLib.read()
		print "Saved :D"
	if request == "load":
		teamLib.read()
		print "Found %d teams" %numberOfTeamsInList
	if request == "quit":
		print "bye"
		alive = False
[/spoiler]
the problem is that when I call teamLib.read(), teamLib.toCommit, which is a list, inserts the contents of ./Scouting/robot (which is a list of dicts) into another list, or (for clarity's sake) I get this:
[[{"teamName": 'YouBots'}]]
instead of:
any tips?
Unread 27-08-2010, 23:44
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Re: Im doing something wrong here (python)
If that's consistently the problem, try doing a simple
teamLib.toCommit = teamLib.toCommit[0]
That might fix up the problem.
GSR Dean's List Finalist 2011
Unread 28-08-2010, 03:21
What does your "./Scouting/Robot" file look like normally? It's hard to just read your code and provide feedback without seeing the data format.
Also, have you looked at "pickling" your data instead of using eval and repr? Pickled data should be faster to load and more secure than eval (which is a giant security hole...). And easier to get working.
Unread 28-08-2010, 08:30
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
I wasn't able to spot the problem exactly, but try to check your objects' values (print them to the interactive shell) just before/after you repr/eval them, and try to see if there was some sort of mistake in there.
Aside from that, here are a couple of tips you might wanna' use to better you program's performance a bit, and make it easier to use:
Enums:
You have yet to represent the type of robot in your outputs, such as prettyfiy(), but I already see that you defined the member robotType as a numeric one, so just in case you'll want to represnt the robot's type in text and not in numbers, you could use enums for that:
Taken from http://stackoverflow.com/questions/3...enum-in-python
def enum(**enums):
    return type('Enum', (), enums)
Used like so:
>>> Numbers = enum(ONE=1, TWO=2, THREE='three')
>>> Numbers.ONE
>>> Numbers.TWO
>>> Numbers.THREE
'three'
You can also easily support automatic enumeration with something like this:
def enum(*sequential, **named):
    enums = dict(zip(sequential, range(len(sequential))), **named)
Used like so:
>>> Numbers = enum('ZERO', 'ONE', 'TWO')
>>> Numbers.ZERO
0
>>> Numbers.ONE
Len(object):
The Len method is used to get the length of an object holding a collection. e.g, a string can be a collection (a collection of single strings or "chars" appended).
You could use it to return the count of items in your list, like this:
    return len(lists)
    # if you use this method only for the toCommit list, do it like this:
    # return len(self.toCommit)
Keep us updated on how the program is progressing.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 29-08-2010, 23:58
1 * 4 != 14
here is ./Scouting/robot: (whitespaced in json-like format for your readability)
    'robotName': 'The lord',
    'robotType': 2,
    'name': 'Bacon Scouts',
    'teamNumber': 1233
    'robotName': "CheeseLord",
    'robotType': 2,
    'name': "The Guys",
    'teamNumber': 2345
Unread 30-08-2010, 01:50
That's your issue. (assuming I'm internally evaluating that correctly...) Python is going to interpret that as an array, and then you are inserting that array into a list. Hence your double packed list.
I'd highly recommend learning how pickling works. It's very easy and better than using eval in that location.
#!/usr/bin/python
import pickle
filename = "p.txt"
f = open(filename, "w")
pickle.dump({1:"a", 2:"b", 3:"c"}, f)
f.close()
f = open(filename, "r")
print pickle.load(f)
f.close()
You could also edit the code to instead use += instead of append. That'll solve your problem as well, but still leaves a security vulnerability.
Unread 30-08-2010, 19:44
1 * 4 != 14
how would you reccomend i proceed with as little security vulnerabilities as possible?
Unread 30-08-2010, 20:58
Web searches recommend JSON, which makes a lot of sense given how the format is put together. Use the cjson module or another similar module to parse JSON rather than eval as you have above. That will do sanity checks rather than blindly trust the code. I was going to recommend pickling until I started reading about the security of pickling. The format is designed for ease of use over security, sadly. It's an interesting read if you are interested in that type of thing.
Unread 30-08-2010, 23:18
1 * 4 != 14
I am intending this to be a library that i can implement in many different ui's (symbian was the origional target, but I am going to write a gtk+ ui for linux and a tkinter one if you really want me to), so i need a 100% python solution. I am most likely going to go with http://pypi.python.org/pypi/simplejson/ as the json parser.
Unread 31-08-2010, 00:05
Sounds reasonable.
What am I doing wrong? grrrrrrr techplex CAN 5 05-08-2010 19:40
Something Wrong with usfirst! Eric W. Jones General Forum 5 09-01-2007 02:01
Something wrong with this picture sanddrag Chit-Chat 2 30-04-2006 12:41
