Go to Post Surprise! There is no ideal alliance. As soon as you think you have a winning strategy, someone WILL figure out how to beat it. - Tom Bottiglieri [more]
Unread 31-08-2010, 18:41
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
[FTC]: And here we go again!
The first hint has been posted!
http://firsttechchallenge.blogspot.c...n-session.html
The graphic is of a bridge and a large gorge... The text is of track and field bases...
hmmm....
Unread 31-08-2010, 23:39
Monty Python Monty Python is offline
Monty Python has a spectacular aura aboutMonty Python has a spectacular aura aboutMonty Python has a spectacular aura about
Re: [FTC]: And here we go again!
So it mentions two obstacles, the bridge and the hurdles. This could be literal and we might have some giant field object that makes movement difficult (a fairly safe bet, considering there's been something that impedes movement at least a little bit every year of FTC). My guess would be something to do with hanging. You can hang off of bridges and hurdles, and we're overdue for a hanging portion as we haven't had one since 2006. Most FTC teams have never had to deal with hanging and so this could be a great new game challenge.
Unread 01-09-2010, 13:27
AKA: Alan
Then there's the reference to bottles, and to shoes... perhaps something with track and field and the scoring object could be those metal sports bottles with the rings?
(yes, those are quickly photoshopped bottles... - No I don't have ones like that... - yes, it would be cool if we did!)
Unread 01-09-2010, 14:36
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
I think Hanging would be awesome with FTC. It would allow people to see what this kit can really do.
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 01-09-2010, 14:50
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
You can hang off of bridges and hurdles...
Don't forget, you can jump/fall off of bridges and jump/tumble through hurdles
The raw materials should make for some interesting winch & lock systems if the game contains a hang.
GitHub
Unread 01-09-2010, 18:08
AKA: Alan
Bungee Cords!
(Maybe they really just don't want us to take FTC for granite...)
Unread 01-09-2010, 19:47
ssi ssi is offline
AKA: David Spangler
FTC #2843 (Under the Son)
ssi will become famous soon enough
The first time one of our team members saw the picture, their first thought was a bridge between two fields. That could definately add a new element to the game, and the matches could become 4v4!
Unread 01-09-2010, 20:21
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
They are going to revive and play "Bridge Battle"???
Unread 03-09-2010, 00:15
ttldomination's Avatar
Sunny
Field is in two parts connected by two bridges...field elements are tubes that you have to transport to your side of the field. Teams will only be able to pick up one tube at a time.
1 point for having a tube on your side of the field.
5 points for hanging a tube in some manner.
20 additional points for each robot that is sitting on its respective bridge at the end of the match.
My guess. It seems a bit boring...but the bridge aspect would be interesting...perhaps the bridge has no side rails or something...
1648: 2013-2014
5283: 2015
Unread 03-09-2010, 09:30
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
He specifically mentions robotics AND unmanned vehicles. perhaps he is also suggesting a longer autonomous mode?
"Don't worry, programming can fix it"
Unread 03-09-2010, 13:10
AKA: Andrew Remmers
That... would be horrible, in my opinion. Ever had to sit there for 30 seconds with no robots doing anything??? Not really that fun or interesting, its the longest 30 seconds ever in my opinion.
Just my $0.02
Andrew
Unread 03-09-2010, 13:30
ProgramLuke's Avatar
ProgramLuke ProgramLuke is offline
Captain
AKA: Luke
FRC #2169 (KING TeC)
ProgramLuke is an unknown quantity at this point
Just my $0.02
Andrew
I beg differ on this point. If we can come together as a community and help make autonomous operation accessible to as many teams as possible then we will be one step closer to making robots instead of remote controlled cars. I feel that the autonomous period should be the primary period, however I accept that not all teams would be capable of this. Once the FTC game is announced I welcome anyone to pm me for help with autonomous in NXT-G, RobotC or Labview.
2012 Inaugural Minnesota State High School League State Champions
2012 Galileo Division Semifinalists
2012 Wisconsin Regional Finalists
2012 Wisconsin Regional Entrepreneurship Award
2012 Lake Superior Regional Chairman's Award
2012 Lake Superior Regional Champion
2012 Lake Superior Innovation in Control
2011 Championship Imagery Award
2011 Championship Archimedes Quarterfinalist
2011 Minnesota 10000 Lakes Finalists
2011 Lake Superior Regional Chairman's Award
2011 Lake Superior Finalists
2010 FTC World Championship Finalist
2010 FTC World Championship Edison Division Champion
2010 Minnesota 10000 Lakes Regional Chairman's Award
2009 Minnesota North Star Regional Chairman's Award
2008 Wisconsin Regional Finalist
2007 Wisconsin Regional Champion
Unread 03-09-2010, 14:34
While I agree with you that autonomous is more valuable than tele-op (the combination of programming and engineering coming together) tele-op does require coding as well and successful teams tend to implement lots of coding into tele-op. I would be more in favor of a challenge that rewards teams that utilize more complex code in tele-op. Then, even rookie teams with no programmers should be able to do something instead of just sitting there even if they won't be terribly competitive.
A longer autonomous really presents you with only a couple of options. You can just sit there doing nothing (which makes the game more boring and, therefore, less interesting to spectators), you can design an excellent autonomous that does any number of things and scores a hundred, thousand points, or you can write a ramming code in 5 minutes designed to stop the aforementioned amazing program. Besides, even the amazing autonomouses (autonomi?) rarely need the full 30 seconds.
In my mind, moving robots attempting to do something>rambots or non-moving robots and a longer autonomous, at this stage, would be bad for the game.
Unread 03-09-2010, 14:44
AKA: Andrew Remmers
Well when it comes to helping other teams I'm all for that, of course we have done that many times in the past even for the most basic to complicated of strategies. I feel automode has always been a key part in the FTC games. Face-off and Hotshot are the only games I know all the rules for, but if you can own automode it can make it incredibly difficult for the other alliance to make up for their disadvantage. Its a great idea for a longer automode for a game aspect, if there is THAT much to do. Sometimes you need that extra 5 seconds or something like that but I think making automode longer than 45 seconds might be a little much. From a personal aspect from waiting for matches to continue on the field and watching games in the stand, it can be very uninteresting, or very thrilling depending on the matches and the teams in the matches.
Andrew
Unread 03-09-2010, 15:24
Captain
AKA: Luke
A good autonomous program should be able to avoid a auto ram-bot.
I am not calling for an elongated autonomous period, I am merely trying to give every team the capability of developing a successful autonomous mode.
[FTC]: FTC Competition kits are here... PhilBot FIRST Tech Challenge 17 10-09-2009 14:24
[FTC]: FTC - Pictures and Videos Here Travis Hoffman FIRST Tech Challenge 14 01-02-2009 22:16
Critical and picky - here I go again. Andy Baker General Forum 40 21-04-2004 11:34
Here we go again... archiver 2001 4 24-06-2002 02:36
2002--Here we go again Ken Loyd General Forum 13 25-10-2001 17:31
