Go to Post I would rather Andy Baker be at champs than Will.i.am. - Grim Tuesday [more]
Unread 08-09-2002, 20:28
Matt VP's Avatar
Matt VP Matt VP is offline
#0074 (Hot Heads)
Matt VP is an unknown quantity at this point
=o
Little something I've been working on for a videogame...
Unread 08-09-2002, 20:37
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
sweet stuff
it will look cooler when textured
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 08-09-2002, 22:44
Matt VP's Avatar
#0074 (Hot Heads)
until I learn lightwave better it's going to be gray
Unread 09-09-2002, 14:40
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
what version of 3ds max was that made in?
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 09-09-2002, 19:00
Matt VP's Avatar
#0074 (Hot Heads)
Lightwave is not 3d studio max
Matt VanderPloeg
AMD Fanboy From Hell
Team 74
Unread 09-09-2002, 19:44
Chris Nowak Chris Nowak is offline
Soudeska?
#0074
Chris Nowak is an unknown quantity at this point
pretty awesome, matt
MSN Messenger - chris_nowak91@hotmail.com
Team 74 - Top Seeded Team in Galileo Division
Unread 03-10-2002, 17:21
stevek's Avatar
stevek stevek is offline
AKA: Master of the Sweatshop
FRC #0230 (GaelHawks)
stevek has a spectacular aura aboutstevek has a spectacular aura aboutstevek has a spectacular aura about
Look good. I spent years with Lightwave, If I can help let me know. I found it easier to learn than Max. Especially texturing and lighting.
Unread 04-10-2002, 12:04
Fufu Fufu is offline
#0093 (N.E.W. Apple Corps)
Fufu is an unknown quantity at this point
Send a message via AIM to Fufu
I admit that the model looks very nice, but unless you have done the model the right way, it wont work in a computer game. I have a friend who has a job doing C++ 3D programing. We have worked together to make some basic 3D programs but it is not easy. Placing object in a sceen is easy, but getting it to have user-controlled movement is very difficult. Another thing that is important is how you create the model. Depending if you use alot of things like meshsmooth, transform gizmos, and so on; the program will use alot of RAM and/or CPU.
I don't mean to discurage you, so keep at it. If you are lucky, it will work just fine.
Also what is the models polygon count?
~Fufu
"The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair." ~THHGTTG
Unread 04-10-2002, 12:27
stevek's Avatar
I've never done modeling for a game, though I've done illustrations for marketing of games- which has nothing to do with the other. I agree with the previous post: you need to take into account alot of things for the optumization of the model (that much I do know). I assume (which isnt always a good thing) that you have been working with someone or reading or some kind of research on how to get from point A to B and then to C. If not, now the time to start. I'm sure you can find books and/or websites that help design for gaming- I believe I've seen them out there. Keep in mind that gaming systems often use processing power that beats the current PC processing power (at least at the time of release) When N-64 came out (I think thats the one) it had a 500or 600Mhz chip when PC's were only running 266 or 300 Mhz. My numbers may be slightly off but the idea is the same. It was several months before the PC's were running comparable processors. This said, there's still a lot of processing that takes place and this all needs to be considered.
Good luck- Don't let anyone steal you dream!
Unread 05-10-2002, 22:36
Matt VP's Avatar
#0074 (Hot Heads)
1. there are no modifiers applied
2. it's all simple polygons
3. it doesn't have a skeleton yet
4. polygon count is around 4000
Matt VanderPloeg
Team 74
Unread 08-10-2002, 01:55
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
One of the most important things when modeling things for games is to determine approximately how many total polygons are going to be displayed on the screen at once, and how many your rendering engine can take before slowing down too much. If you are going to have many instances of a model on the screen at the same time, you need a much smaller poly count.
For example, in Warcraft 3, I seem to remember that none of the models exceed 300 polys. Since so many models are on the screen at once, they need small poly counts.
The same was true when I did modeling for Counter-Strike. I don't remember exactly, but I think CS models were around 800 polys. They used smoothing groups (a very easy thing to do in MAX) to make things seem rounded. If you zoom in really closely on any CS model's helmet, you can probably tell where the edges of the polygons that make the helmet up are, and see the smoothing.
Unread 16-10-2002, 08:19
Matt VP's Avatar
#0074 (Hot Heads)
We are allowed 8000 polygons per model (still, many are 2000). The game wont be released for a long time and we are not expecting anyone with less than a Geforce 5(NV30) to be able to play it.
Matt VanderPloeg
Team 74
Unread 16-10-2002, 15:17
MBiddy's Avatar
MBiddy MBiddy is offline
Groovy!
#0862 (Lightning)
MBiddy is an unknown quantity at this point
Send a message via AIM to MBiddy
What a wide audience.
Unread 20-10-2002, 11:55
Matt VP's Avatar
#0074 (Hot Heads)
Audiance isn't important, we're making it for ourselves. It's not even likely that the game will be sold. The game wont be finished for at least 2 years. If you don't have something better than a Geforce 5 by then: sounds like a personal problem.
Matt VanderPloeg
Team 74
