Go to Post Temp wiring is always bad but it is made worse when dealing with a $1000 part. You wouldn't try to lash a makeshift power source to your PC. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 07-10-2002, 21:07
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Drawing Confusion
While building our tall towers we hit a confusing block.
In one drawing the PVC is aligned as:
whereas another one is:
--- will edit later with a picture ---
basically, top one is 4 seperate pvc tubes for each tower (16 total), second is a central 4 tubes with two outer tubes for each (
Unread 08-10-2002, 07:56
Justin Howard Justin Howard is offline
Justin Howard is an unknown quantity at this point
The field layout is incorrect. There should only be 12 PVC pipes not 16.
Unread 09-10-2002, 13:25
Gadget470's Avatar
A Fire Outside
rockin'
Thanks, so crappy ascii drawing #2 from my post it is
Need help drawing my ideas Keith Chester Technical Discussion 12 08-11-2003 20:09
Maxi Block Confusion? Adam Shapiro Electrical 11 26-01-2003 20:23
This years Feild CAD drawing needes in .DXF format archiver 2000 1 23-06-2002 22:51
Additional Hardware list confusion archiver 2001 4 23-06-2002 22:29
New Field Drawing Brandon Martus OCCRA 3 25-11-2001 17:31
