Go to Post We figured it out. - benjiengi [more]
Unread 01-09-2010, 16:28
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Let's Collaborate: FRC Electrical/Systems Troubleshooting Manual
I've had this idea for a couple years now, but due to a whirlwind of a season last year haven't had the chance to pursue it.
Background:
Each year it seems like an electrical/networking snafu happens to my team. We'll either lose connectivity, a PWM cable will come loose, the a sensor will trigger prematurely, etc, etc, etc. Students, mentors, FTAs, and who knows who else will take a look at the robot and say, "Do this, this, this, aaaannd.... that." After about 10 people come by to help out, the problem seemingly fixes itself. The team is happy. Then someone (usually a freshman) asks, "So what did we fix?" to which the entire team scratches their heads and replies, "aldkjf4Q#@(%asfj[imagine many voices speaking at once here]@#($ASJfdasf4#$1".
I'm sure many others out there know what I'm talking about.
And each year this happens, I say to myself, "I really need to sit down and write an in-depth troubleshooting manual where we could have gone step-by-step through an order of operations, so we could have known exactly what was the problem."
Proposal:
If a magical manual that could solve this issue exists, please post it here and the mods can close this thread. If not...
I've decided to crowd source this thing. Some of the smartest and most experienced FIRSTers are on CD, so this is a great opportunity to create a quality resource everyone can use.
Maybe we divide the manual up into sections:
- Robot won't boot
- Loosing comms.
- Watchdog not fed
- Robot drives, but not how I want it to!
- and more?
Next steps
If you're interested in working on this, or just have any other thoughts about this, reply to this thread. Don't just start posting informal lists of "this is what team so-and-so does", because who ever is going to work on this needs a better way to collaborate than CD - maybe I could set up a wiki on the COMETS' website or use some free web service. Suggestions are most welcomed.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 01-09-2010, 16:44
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Let's Collaborate: FRC Electrical/Systems Troubleshooting Manual
I like the idea. An issue I would suggest is a motor controller not getting signal.
- Arizona North
Unread 01-09-2010, 17:10
GGCO's Avatar
AKA: Grant
FRC #3357
Ooooh!! That's a good one.
The FIRST Alliance
COMETS Robotics
Website
Unread 01-09-2010, 18:26
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Generally it can be solved easily though process of elimination and a little luck to make it go faster. You need to always determine if the problem is mechanical, electrical or programming.
I like to blame the programmer first but you must start with mechanical.
1. You can use another system to check that the mechanics of your system is working. Power up motors to see if they are working.
2. Check from one end to the other that all items move as they are suppose to.
3. Check and recheck that all sensors are working constantly. After three uses it may change or the speed it is actuated may not be detected by the computer randomly.
4. Check and follow every single wire and make sure all polarity is correct.
This is why it is important to label and organize your wiring. Keep the 12 volt separate from the low volt. It will make it faster to trace.
5. If all the mechanics and wiring check out than start investigating the program..
An effective manual would be difficult to make but could be helpful. There are so many variables to why something is not working.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 01-09-2010, 19:14
You might find it helpful to browse other similar threads, such as this one: http://www.chiefdelphi.com/forums/sh...ad.php?t=83634
Unread 01-09-2010, 20:09
GGCO's Avatar
AKA: Grant
FRC #3357
Thanks for the link. Definitely helpful, but the vision I have for this thing is that it be a comprehensive guide for communication and basic electrical issues.
I'm thinking I'll start a wiki. Thoughts?
The FIRST Alliance
COMETS Robotics
Website
Unread 01-09-2010, 23:53
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
As part of a team plagued with such issues and as such I really like the idea of a comprehensive electronics/systems troubleshooting guide.
However I really don't think I could help much because I am rather weak (I lnow how to set up the stuff but really don't know much else) in the electronics portion in the robo; part of the reason that we have so many problems.
This sounds like a great idea.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 02-09-2010, 00:06
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
I agree, a wiki would be an excellent tool. I would definitely be willing to contribute anything I find/learn.
GSR Dean's List Finalist 2011
Unread 02-09-2010, 10:27
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
For a 'user' manual, the key point made here is: check your connections, or swap to better connections ahead of time.
Case 1
Most of our electronics problems were solved in 2009 by these guys (we don't buy them there; that's just the first place I found a picture). Combined with the appropriate crimp tool, our electronics board is not only modular, it is incredibly easy to fix a connection and we haven't had a mysterious random shutoff since 2008. We mainly went to the mini Anderson PowerPoles when we realized that we kept loosening the wires within the default KOP crimps while changing a motor or victor. The other issue we had, even with good electronics toolbox organization, was that we would recrimp a wire with the wrong-sized connector (which caused this little guy in Atlanta 2007 -- luckily our post-match checkups caught this before it caught fire). So for a random subsystem shutdown, check the leads. It seems like an obvious solution, however finding the problem connection is sometimes VERY challenging.
Case 2
The other thing to check is your BATTERY connection. The battery wire leads should be SOLID, NOT MOVING, and COVERED. Picking up a battery by its wires will eventually deteriorate the connection and cause the described random shut off. The "fix" your team did may have been to simply replace the battery. As dumb as that may sound, we've had many matches (ranging from FTC to VEX to FRC) where a bad battery connection has been the culprit of random system-wide shutdowns; the cause could be traced back to battery mishandling.
If the drive train stops responding, the problem may be a combination of a bad battery connection combined with improperly-designed drive train or control code. For example, the drive train may shut off during long sweeping turns if the code only tells one side of the drive train to go forward, yet the motors on that side must pull an excessive amount of current to generate the torque necessary to make the robot go forward and turn (depending on wheel traction and wheel base). If the battery has a bad connection, it may only allow 30-50 amps of power; this is enough allow the drive train to go full-forward and other robotic systems to function, yet in a sweeping turn the drive train may pull more current than that connection allows is physically capable of handling. Thus the drive train stops responding. The solution here is twofold, though the first is a stop-gap measure while the second is a must-fix issue: disable long-sweeping turning in the code, and inspect/fix the battery connection.
PWM Cables
Use clear nail polish. It's non-conductive, comes of cleanly, and is easy to cleanly apply. Stick the PWM cable into the Victor/Jaguar connection, verify that it works properly, then put a small dot of clear nail polish where the black plastic PWM connector touches the plastic on the Victor/Jaguar. The FRC electronics designers finally got something correct with adding lock tabs to the digital/analog sidecars, yet IFI/Luminary Micro still miss this (IMO, critical for anything industrial) function.
GitHub
Unread 02-09-2010, 14:08
Originally Posted by JesseK View Post
PWM Cables
Jesse,
I have to agree on the rest of your post but I am firmly against the use of permanent or semi-permanent attachments for critical connections. Adhesives (hot glue, nail polish, super glue) should be avoided when you may need to change a defective part quickly during a finals match. I recommend that teams find a way to attach the PWM cable near the device with a tywrap. The Jaguar has some clips molded into the body for this purpose. If the cable is holding down the connector, i.e. no slack, then the connector cannot pull out. A simple cut with a small side cutter is all it takes to remove the cable. We use punched aluminum sheet to mount electrical items and the holes are perfect for this purpose.
For my two cents, learn early that a voltmeter does not tell you the condition of the battery unless it is under load. Dead or near dead batteries will cover about 50% of all electrical problems but will read 12 volts on a voltmeter with no load. If many things do not work on the robot that have before, change the battery. Don't believe that a student gave you a charged battery try another one. The Crio senses battery voltage through the jumper on the analog card for module one only. If the battery voltage falls to 5.5 volts, the Crio disables all outputs. When the battery voltage rises, the Crio will start operating again until the battery falls to 5.5 volts. Watch the drivers display to check battery voltage. The power supplies in the PD will fail at about 4.5 volts. When the 24 volt supply fails the Crio reboots, the 12 volt supply failure causes a reboot of the gaming adapter and a five volt failure causes the camera to reboot. They do not all fail at the same time, so as luck would have it, you may not have communication re-established following a power brownout.
Learn to listen to the robot, it is talking to you. LEDs will tell you a lot about the health of all the systems, sounds will tell you if something is wrong mechanically, and for what you can't see or hear, smell will tell you if something is overheating or has burned. You will never forget the smell of a burned FP motor or a bad speed controller. While we are on the subject, the LEDs on the sidecar can glow dimly with current leaking through the data connectors. Make sure that they are bright and supplied with a good external power connection. Use your voltmeter at the power in connector to insure that the sidecar has power.
For your benefit and those of your inspection team, don't hide electrical parts where they can't be seen. If we can't see the LEDs on everything, we can't help you play.
Unread 02-09-2010, 15:33
kaliken kaliken is offline
294 Old Fart Mentor...
AKA: Ken S
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
I wanted to add to the battery comments. Many many of the times things were not quite working right ended up being due to the battery not being charged or good.
As Al mentioned a voltmeter does not give a state of health on the battery. In Atlanta we found out that we only had brought 4 solid batteries out of the 8 we had shipped. The only way we found out was through a load tester that 1114 gratiously let us borrow. Needless to say the first thing we bought when we got home was the exact same battery tester as 1114.
I'll list it here: its an Midtronics SCP-100 SCP 6/12
http://www.midtronics.com/home/finda...rs/scp100.aspx
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
Unread 04-09-2010, 14:39
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Joe, thanks for posting my thread. I knew I had done something like this, but had stopped because it was a lot of work to lay out clearly in flow diagrams.
A lot of problems originate from plugging things in wrong. You know that the same style of connector is used for Analog inputs, Digital inputs, Digital outputs, PWM outputs, and Relay outputs. It's not keyed, and it doesn't come labeled.
I highly reccomend getting a adhesive-tape labeler and labeling each data cable on both ends. Also, mark up your motor controllers, sensors, Digital Sidecar, and Analog Breakout so it's obvious which way to plug the cable in. (It's not fun when you fry a $60 gyro because the cable was in backwards and 5v and 0v were reversed)
Here's an example of a marked-up Jaguar:
-- Marshal Horn
Unread 06-09-2010, 14:32
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
I'm by no means a programmer/electrical person, but if you do this I have a possible request. This may already exist or have some completely different fix/be impossible, but here goes:
I end up intermittently coordinating our programming sub-team. (why? good question. we're working it...) Unfortunately, we have trouble understanding, not to mention fixing, all the error messages that can come up on the dashboard. We've started to develop a quasi-symptom based list: e.g. "this one means reboot the computer", "that one means push OK really fast until it disappears", "that one you should just drag into the corner and ignore". ...This doesn't strike me as the best way to handle the situation. It's (rather unsurprisingly) gotten us into/not out of some difficult spots before.
So if it's possible, we'd really appreciate a reference list of error and explanations and/or fixes. Keep in mind that I honestly don't know what this entails, all I know is that my team (who does have a better grasp of programming) really wants it. I'd appreciate any direction you'd like to offer.
[/non-programmer-electrical talk]
Unread 06-09-2010, 14:51
GGCO's Avatar
AKA: Grant
FRC #3357
Good idea. What error messages do you see though? I'm especially curious about the ones that produce popup dialogs - don't seem to recall any of those.
I'm going to talk to my team at our next meeting (two days from now), and probably create a wiki somewhere this week.
The FIRST Alliance
COMETS Robotics
Website
Unread 06-09-2010, 17:55
Siri's Avatar
Dare greatly
Thanks, good question. I'm currently away at school, but I'll see if we can't get a list together. Thank you.
non-'FRC legal' control systems? Otaku Control System 15 05-03-2009 16:26
diversified systems at FRC Kickoff-NH www.divsys.com General Forum 1 02-01-2008 19:34
Electrical schematics Manual??? j_howard61 Electrical 9 08-01-2007 08:26
Electrical Systems and ideas... mechanicalbrain Electrical 28 17-08-2005 07:03
Robot electrical systems rules Morgan Jones Rules/Strategy 5 06-01-2002 00:50
