Go to Post Save the frustration for build season. :p - Brian C [more]
Unread 23-08-2010, 19:34
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
2010 Image Demo
Hey I have a question about the 2010 Image Demo. Do you need to have a gyro in order for it to work? Also, the camera is hooked up but doesn't show on the driver station. Is this normal?
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 23-08-2010, 23:57
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: 2010 Image Demo
I believe the Gyro is only necessary in Autonomous. If you don't have it hooked up, then your direction will always be 0.
The camera image should show up on the Dashboard if it is hooked up and correctly configured. There are instructions for camera configuration on page 58 of Chapter 2 of the Control System Manuals at http://usfirst.org/frccontrolsystem.
-- Marshal Horn
Unread 01-09-2010, 19:58
Rangel's Avatar
John Rangel
Re: 2010 Image Demo
I have a problem, when I type in the cameras ip, it asks me to log in. I type root for the username and pass for the password but it doesn't accept it. When I enter the username and password it looks like it refreshes. Any ideas?
2014-? Mentor
Unread 01-09-2010, 21:54
Re: 2010 Image Demo
What web browser are you using? Early last year I discovered that Safari wouldn't work to log in to the camera, giving the "refresh" you describe. Someone else tried Firefox without success, but I think he was confused about what the password was supposed to be, so I can't say whether it was actually failing the way Safari did.
Internet Explorer worked correctly.
Unread 02-09-2010, 18:31
Rangel's Avatar
John Rangel
Re: 2010 Image Demo
I followed all the instructions and this time used internet explorer and everything looked like it worked but we are still not seeing a camera image in the driver station. We can see the camera image when attempting to modify though.
2014-? Mentor
Unread 03-09-2010, 18:08
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: 2010 Image Demo
Is the ring of light on the camera green when the robot is running?
also fyi the camera takes much longer to boot than the rest of the robot, so the images starting will be slightly delayed
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 03-09-2010, 18:16
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: 2010 Image Demo
Are you saying that the Dashboard shows the camera image when run as a VI, but not when run as an .exe?
-- Marshal Horn
Unread 04-09-2010, 21:32
Rangel's Avatar
John Rangel
Re: 2010 Image Demo
The camera light is green but on the dashboard, the camera image is white.
2014-? Mentor
Unread 05-09-2010, 11:42
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: 2010 Image Demo
Could you take a screenshot?
If it's that dimpled texture, then that means it's not getting an image. If it's actually solid white, then that means the image it's receiving is all white, which is a strange image indeed.
-- Marshal Horn
Unread 07-09-2010, 10:34
Rangel's Avatar
John Rangel
Re: 2010 Image Demo
Here is a screenshot.
2014-? Mentor
Last edited by Rangel : 07-09-2010 at 10:36. Reason: Didn't upload attachment properly
Unread 07-09-2010, 11:13
Re: 2010 Image Demo
How come your Dashboard is broken?
Unread 07-09-2010, 15:21
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Re: 2010 Image Demo
If you look in the top right corner just above the actual dashboard, you will see an arrow. When the arrow is broken like it is in your picture, it means something isn't wired right on the block diagram. That's probably why you aren't getting a picture.
Unread 07-09-2010, 18:18
Rangel's Avatar
John Rangel
Re: 2010 Image Demo
Sorry, I posted the dashboard of another driver station on a different computer because the programming laptop was not accessible. Here is the real print screen. Also, we are programming in windriver.
2014-? Mentor
Unread 07-09-2010, 18:57
Rangel's Avatar
John Rangel
Re: 2010 Image Demo
Here is the print screen of the configuration. Here, we have an image.
2014-? Mentor
Unread 07-09-2010, 19:47
Re: 2010 Image Demo
Since you can connect to the http server on the camera and see that it works there, switch to the config pages and look at the user accounts and settings. In particular, see that the camera has an account with user name of "FRC" with same for password. This is normally done by the Camera Configuration, but can also be done by hand.
Greg McKaskle
Decoupling the image acquisition from the Image Processing Tom Line Programming 8 09-03-2010 17:52
2010 FRC camera vision tracking delay, image processing lag pspeer C/C++ 18 18-02-2010 07:24
Running a .out file from 2009 with a 2010 image GabeRC1717 C/C++ 4 14-01-2010 16:19
