Go to Post CD would not be what it is without Brandon - Richard Wallace [more]
Unread 04-09-2010, 19:46
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
Working with the PSoC
I am currently working on how to work with the PSoC. It uses a special form of C. I had the idea to create something like a sub computer with it, setting it up with some RAM and an external data source. my only problem is, I don't know how to program the thing in the first place!
I have a little experience with C++, but only with windows programming. I don't have a clue on how to do hardware programming in C. Help Please!!!!
Latin:
"Murmure ventus erit parere Tempestatem"
"Noctu teneris vinculis
Nocte illa vincula adimuntur"
Unread 04-09-2010, 21:13
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Re: Working with the PSoC
I'm a bit confused at what you are trying to do with it. Are you doing something seperate from FRC with it or are you just trying to use it for the driver station IO?
"Don't worry, programming can fix it"
Unread 04-09-2010, 21:25
Team Role: Student
This is for next years' compitition. You see, no one on my team know how to work with the PSoC. So I'm pretty much doing all of the work on it. My idea is to set up a base control program in the PSoC, and then create special programs stored on SD cards. The SD cards are inserted into a SD slot on the control station, and the station sends the data to the PSoC on the robot. Are you following me so far?
Latin:
Unread 05-09-2010, 11:37
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
That sounds interesting.
I think the biggest problem you'll run into is that FIRST hasn't released their source code for the PSoC or the Driver Station.
Here's a thread from a year ago on this:
http://forums.usfirst.org/showthread.php?t=13082
-- Marshal Horn
Unread 05-09-2010, 13:00
Team Role: Student
I don't need their source code. I intend to write my own. The reason I started this thread was because I need some tutorials on PSoC hardware programming. I noticed that I can use C++, so that will be helpful in the programming process. But in my final project, because I intend to use an external memory system(RAM), I need to use a good bit of C. So can anyone post tutorials on PSoC3 hardware programming?
Latin:
Unread 05-09-2010, 14:09
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Oh, I'm sorry, I misunderstood you.
I thought you were intending to put the PSoC on the driver station.
The User's Manual has a basic example. Here's a list of sample projects:
http://www.cypress.com/?id=1353&rtID=113
-- Marshal Horn
Unread 05-09-2010, 17:20
AKA: Bobby
I'm not sure on the rules for using the PSoC in that way are. If its legal, that sounds like a great idea and I may be interested in doing the same, but I have a feeling there will be a rule somewhere stopping you.
Unread 05-09-2010, 19:28
Team Role: Student
The only rules for custom electronics are that the circuit cannot interfere with another teams robot in any way, shape, or form. that and the electronics cannot be outside of the robots footprint.
Latin:
Unread 05-09-2010, 20:29
<R03> Custom circuits and COTS electronics are expressly PROHIBITED if they:
A. Interfere with the operation of other ROBOTS.
B. Directly affect any output devices on the ROBOT, such as by directly powering a motor, supplying a PWM signal directly to a speed controller or supplying a control signal directly to a relay module (see Rules <R63> and <R64> for the specific exception regarding CAN-bus devices).
<R50> Custom circuits shall NOT directly alter the power pathways between the battery, Power Distribution Board, speed controllers, relays, motors, or other elements of the robot control system (including the power pathways to other sensors or circuits). Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the ROBOT’S electrical system is acceptable, because the effect on the ROBOT outputs should be inconsequential.
8.3.8 Custom circuits may be used to indirectly affect the robot outputs by providing enhanced sensor feedback to the cRIO-FRC to allow it to more effectively control the ROBOT.
<R68> All outputs from sensors, custom circuits and additional electronics shall connect to only
A. other custom circuits, or the following:
B. additional COTS electronics, or
C. input ports on the Digital Sidecar, or
D. input ports on the Analog Breakout, or
E. the RS-232 DB-9 serial port on the cRIO-FRC, or
F. the Ethernet bus connected to Port 2 of the cRIO-FRC, or
G. the CAN-bus if and only if all Jaguar speed controllers on the CAN-bus are wired in full compliance with Rule <R63> and Rule <R64>, or
H. the sensor inputs on the Jaguar speed controller.
Custom circuits and additional electronics are allowed to utilize the Port 2 Ethernet bus and/or the CAN-bus to communicate between devices. Note however, that the ROBOT must be controlled by the cRIO-FRC (see Rule <R56>). Thus, any additional devices on the Ethernet or CAN-bus must not provide command signals that do not originate from the cRIO-FRC It is our intent to incrementally open access to the full control system technologies in a controlled manner that reduces the risk of “unanticipated surprises” as we gain experience with the system.
Unread 05-09-2010, 23:49
Team Role: Student
My idea follows all of the rules. the system is only for dectecting enviromental changes and telling the cRIO how to react using preprogrammed commands in the cRIO. that is all I want the PSoC to do. also, don't forget that those were last years rules. the rules could be different this year.
Latin:
Unread 06-09-2010, 00:57
I see I don't need to give any of my standard warnings
For what it is worth (nothing), my understanding of last years rules agrees with (my understanding of) your understanding.
The best advice I can give you is to plan your project out into small, proveable chunks. At each step along the path, you should be able to point to something and say "this proves that it is working the way I think it is".
For example, it may be worthwhile to make a simple version in which it simply reports whether or not something is true using a simple pin. You can attach an LED or a multimeter to this and watch it blink.
Also, don't be intimidated by the PSoC's programming environment. If you already know C++, you are well on your way. Again, just start simple.
As to its hardware configuration, this is done graphically. The interface is relatively straight forward, but I'd do a tutorial or two first just to get a lay of the land.
Unread 06-09-2010, 01:46
Big Kid's Avatar
Big Kid Big Kid is offline
The Coach
AKA: Nick Acosta
FRC #0816 (WesTech Anomaly)
Big Kid is a jewel in the roughBig Kid is a jewel in the roughBig Kid is a jewel in the rough
Send a message via AIM to Big Kid
If you look through this year's rules there is something stopping you.
<R60> The control system is designed to allow wireless control of the ROBOTS. The Classmate PC, FirstTouch I/O module, cRIO-FRC, speed controllers, relay modules, wireless bridge, batteries, and battery charger shall not be tampered with, modified, or adjusted in any way
A. User programmable “dashboard” code in the Classmate PC may be customized. (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.), with the following exceptions:
B. User programmable code in the cRIO-FRC may be customized.
C. Dip switches on the cRIO-FRC may be set.
D. Speed controllers may be calibrated as described in owner's manuals.
E. The supplied fans attached to the Victor speed controllers may be powered from the Victor power input terminals.
F. The fuse on the Spike relays may be replaced with a 20 Amp Snap-Action circuit breaker.
G. The alligator clips on the battery charger leads may be replaced with Anderson Power Pole connectors (note: this is a recommended modification).
H. Wires, cables, and signal lines may be connected via the standard connection points provided on the devices.
I. Fasteners may be used to attach the device to the OPERATOR CONSOLE or ROBOT.
J. Labeling may be applied to indicate device purpose, connectivity, functional performance, etc.
K. Brake/Coast jumpers on speed controllers may be changed from their default location.
L. If CAN-bus functionality is used, limit switch jumpers may be removed from a Jaguar speed controller and a custom limit switch circuit may be substituted (so that the cRIO-FRC may read the status of the limit switches).
M. If CAN-bus functionality is used, the Jaguar firmware must be updated as required by FIRST (see Rule <R63-D>).
N. If the FirstTouch I/O module is not used as part of the OPERTOR CONSOLE, the embedded software may be modified. If the First Touch I/O module is used as part of the OPERATOR CONSOLE, the default software image must be used.
Sure there is a possibility this rule ceases it's existence for the 2011 season.
Team 816
Student (2007-2011)
Mentor/Drive Coach (2013-)
Team 2495
Mentor (2016-)
Graduate Mech. Engineer at Lehigh University
Unread 06-09-2010, 11:22
Team Role: Student
The Cypress IO board is going to be on the robot, not attached to the control console.
Latin:
Unread 06-09-2010, 13:50
Big Kid's Avatar
The Coach
AKA: Nick Acosta
Ah okay then, sorry about that, I did misread your earlier post.
I find that this would definitely be a good idea, seeing as the PSoC card also has a fair amount of sensors on it too. The proximity sensor on there for example might of been useful for this year's game.
Team 816
Student (2007-2011)
Team 2495
Mentor (2016-)
Unread 06-09-2010, 14:18
Team Role: Student
As I work out the symantics of my base program and the circuit schematics, I will post attachments so that way, everyone is on the same level.
Latin:
Help with PSoC board programming please krudeboy51 C/C++ 23 21-10-2010 19:54
Help with PSoC board wiring please krudeboy51 Electrical 1 04-05-2010 16:17
Programming the Psoc railerobotics Technical Discussion 5 18-02-2010 10:10
Windows "Malfunctioning USB Device" error with Psoc IO Board WarrenPW FRC Control System 2 11-02-2010 18:53
Programming the PSoC PortugazD.Ace Programming 19 31-01-2010 13:14
