Go to Post Mentors learn from, are inspired by, and emulate each other. A team with a great lead mentor leads to a productive, inspired, and ultimately successful group of mentors. - Jared Russell [more]
Unread 05-09-2010, 23:30
Re: reverse-voltage protection
Marshall,
I would be willing to bet that the majority of dead controllers due to wiring errors are for the input and output to be reversed. Remember that the HEX power FETs that are used have a diode across the source drain leads that is a fall out of the manufacturing process. The series diode would still need to handle 129 amps, the stall current of the current CIM motors. Schottky diodes have a lower forward voltage drop but are too expensive and large to be included in the controller design. We use the smaller Anderson connectors for all/most of our motor connections. The 45 amp version handles the CIM motors just fine. There is not enough heating in a two minute match to damage these connectors provided that the correct crimper is used to terminate the wire.
Protection Spiders Technical Discussion 3 11-02-2008 21:37
Eye protection gnirts General Forum 9 13-01-2007 20:28
floor protection Ken Leung Off-Season Events 15 17-05-2003 07:42
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 01-03-2002 08:55
Claimed CD-Protection Kyle Fenton Chit-Chat 19 31-01-2002 04:16
