Go to Post Lawrence North has air conditioning. If it didn't, more than just balls would be sticky. - Andy Baker [more]
Unread 06-09-2010, 03:10
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Home-brewed Robot Control System (2 computer running LabVIEW, with the old 2008 R
Originally Posted by squirrel
What are you using for communications...the IFI radios?
Most likely 802.11g using AdHoc between the two PCs.
Originally Posted by kamocat
Have you considered turning a laptop into a LabVIEW Real-time Target to put on the robot?
No, but what I have right now is working great. The only lag in the system is between the two PC's, which is not even noticable on a closed network. It is, however, noticable from 1/2 a mile away in your dorm room while you're in a remote desktop connection to the base station.
Originally Posted by BornaE
To send video from the Robot PC to the Base Station, you need to flatten the image into a string. make sure it has JPEG compression and then send over your network. then receive. convert to image and display.
Fairly simple to do. message me on skype if you need further help
We had a miniITX motherboard on our 2010 robot doing image processing. Also redid all of the image transfer code from the robot to the DS and the dashboard to display it from scratch to get 30FPS video.
That's easier said than done. lots of compatibility constraints for the realtime target.
That's what I was thinking. I was trying to flatten it to a string using the PNG format, but I got a string too long to send over the network. I'll give the JPEG a try.
I've also been looking at the MiniITX Motherboards on Newegg.com. The only problem with going that route is I have to get a 12V DC input power supply to make them work, plus the lack of display or any controls for that matter (mouse, keyboard) will make operating the robot PC very difficult to do if the remote desktop connection fails for some reason. I can get a netbook for fairly cheap, and I'm also juggling around the idea of using my old Dell E1505 on the robot and sticking my OCZ SSD drive that I have for my MacBook Pro in there for the competition. I would have to run a power inverter to make it work though.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
using CAN with the 2010 control system Us3rNam3 NI LabVIEW 12 01-02-2010 13:04
Do we have to ship the control system along with the robot on Tuesday? tennisbeast29 Rules/Strategy 3 14-02-2009 13:39
pic: '08 robot with '09 control system Alex Dinsmoor Extra Discussion 11 11-12-2008 20:01
Control Robot with Computer Sykan Programming 5 28-09-2008 01:13
Running Multiple Robots with the old Radios cbale2000 Technical Discussion 4 18-10-2007 19:40
