Go to Post #TeamFrank - Libby K [more]
Unread 03-09-2010, 21:31
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Re: [FTC]: And here we go again!
a complex autonomous could be built were it not for the NXT's horrible memory management. I don't know about other teams, but i constantly had to tweak my teleop before i even built autonomous to fit on the NXT last year.
"Don't worry, programming can fix it"
Unread 09-09-2010, 11:34
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
The key to making your NXT programs smarter jet still fit in the NXT is to make strong use of SubVI's (or subroutines).
The code for these is shared, so they take up less room than two sets of duplicate code.
So if you find yourself adding the code to turn 90 Dec several times in your program, you can make your program smaller by creating a SubVI to do that turn.
Better yet, make a SubVI that has the turn angle as an input.
We had an Auto program last year that had 12 different move patterns.
We just kept making the SubVI's smarter, and more generic, till we got to the point that every Auto sequence was built up from three or four VI's (which managed moving and shooting).
To add an entire new sequence we just had to call the existing VIs. This required very little extra code or memory.
Remember. Cut & Paste is the enemy of programs. If you find yourdelf doing a cut & paste of C or LabVIEW code, it's time for a Subroutine or subVI.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 10-09-2010, 13:55
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron)
I'm not a master C programmer yet but when it comes to programming in the language follow the KISS method is how we do it and the world championship last year proved us right in most respects. Now this year we are doing aLOT more sensor based programming to a small extent but what people didn't realize last year I didn't see a single team out there where that Infared sensor worked consistently. Now Line following...I liked that i have heard it was VERY reliable for autonomous espcially.
Within your code for C make sure you're not repeating your int statements at the Tennesse regional espcially I went around helping teams alot of them had 2-3 in statements reintializing the same thing multiple times.
And going to what Phil said about in LabVIEW those subVI's can sometimes make or break you on file size requirements.
Have fun this season
John Fogarty
John Fogarty
"Head Bot Coach" FRC Team 4901 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1102, FRC 1772, FRC 5632
Unread 10-09-2010, 14:09
PhilBot's Avatar
AKA: Phil Malone
For the record, our IR sensor worked 100% reliably.
If we ever missed a goal in Auto, it was because our shooting height fluctuated, or somene blocked the robot from getting in position. If not, we were always dead center.
It also worked really well in teleop. We had single button for aim-and-fire. If the driver got the distance right, it was always on target.
The Key to a useful IR sensors was using the required 30 degree offset (to center the narrow beam on the target) and then comparing the intensity of the two beams on either side to split the absolute center of the beam.
ps: it also helps if you don't let the beacon battery go dead
Phil.
Phil Malone
Unread 11-09-2010, 08:17
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
I just finished the game animation a couple days ago. Wow, the Game Design Team at FIRST did a great job coming up with some fun challenges this year! I'm looking forward to seeing all the innovative robot systems the teams design to meet those challenges.
I probably shouldn't do this, but here is a link to the last frame of the game animation.
Unread 11-09-2010, 10:07
PhilBot's Avatar
AKA: Phil Malone
Real helpful.....
I suppose I should just "Get over it".
Phil Malone
Unread 11-09-2010, 12:21
ttldomination's Avatar
Sunny
Anyone know when the information goes live on the FIRST website?
1648: 2013-2014
5283: 2015
Unread 11-09-2010, 12:50
PhilBot's Avatar
AKA: Phil Malone
You need to look around a bit.
It's on the main FTC page.
5:00pm EST Sat 9/11
http://www.usfirst.org/roboticsprogr...nt.aspx?id=962
Phil.
Phil Malone
Unread 11-09-2010, 15:49
Sunny
5:00pm EST Sat 9/11
Phil.
I do apologize. After posting here I went to the FIRST page and there it was.
1648: 2013-2014
5283: 2015
Unread 11-09-2010, 16:01
AKA: Bobby
Talking Re: [FTC]: And here we go again!
I'm so excited, i spent my morning intensly reading the Samantha files and info, and i've kept a timer open for how long until 5 PM. Being co captain of the team this year, I'm very eager to bring our team to fame and fortune.
I have a not so healthy obsession with FIRST i think, but then again so does everyone else here.
Unread 11-09-2010, 17:02
fireyoshi fireyoshi is offline
Go 3411!
AKA: Kleber Pauta
FRC #3411 (Team Intrepid)
fireyoshi is an unknown quantity at this point
The game is called Get Over It.
http://www.usfirst.org/roboticsprogr...lt.aspx?id=968
The timer page is being glitchy, though.
EDIT: Or not, the video is up.
2010 Bayou Regional Rookie All Stars
2010 Bayou Regional Highest Rookie Seed
Unread 11-09-2010, 22:26
PhilBot's Avatar
AKA: Phil Malone
Real helpful.....
Called it !!
Phil Malone
[FTC]: FTC Competition kits are here... PhilBot FIRST Tech Challenge 17 10-09-2009 14:24
[FTC]: FTC - Pictures and Videos Here Travis Hoffman FIRST Tech Challenge 14 01-02-2009 22:16
Critical and picky - here I go again. Andy Baker General Forum 40 21-04-2004 11:34
Here we go again... archiver 2001 4 24-06-2002 02:36
2002--Here we go again Ken Loyd General Forum 13 25-10-2001 17:31
