Go to Post Your robot weight goes up after you release the balloons. Re-inspection! - GaryVoshol [more]
Unread 11-09-2010, 22:11
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Re: Thoughts about the new FTC challenge?
Check out FRC 2001
I think this was the last time I saw this balancing act
Unread 11-09-2010, 22:16
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Originally Posted by Bertman View Post
Check out FRC 2001
Not many FRC robots at that time had an automatic leveling routine which was likely the result of the BasicStamp based CPU and not having COTS items such as an accelerometer/tilt sensor.
Now you can make robots that know which way is up! The HiTechnic Accelerometer / Tilt Sensor measures acceleration in three axes. It also measures tilt along each axis. <snip>This sensor will also tell you if your robot is level so you can build self-leveling robots and much more.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 11-09-2010, 22:32
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Originally Posted by Andrew Schuetze View Post
Why not use a magnetic sensor in your baton manipulator
I was unaware that one existed from HiTechnic, but that sounds much easier thanks.
And that rule may be something you want to bring up with FIRST, they're bound to revise that rule if they find it.
"Don't worry, programming can fix it"
Unread 12-09-2010, 00:27
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Originally Posted by alphadog0309 View Post
alright so i have found an issue in the rule book and i wonder if this seems right to you guys....
on pg. 10, under game definitions (2.3) the definition of Possess / Possessing a Baton reads as follows:
"A robot is said to be Possessing a Baton if any part of the Baton is in
contact with the robot.
this implies that if the robot is driving over a baton, it will count as being possessed therefore pushing a team over the maximum of 5 possessed batons, causing a 5 point penalty PER BATON IT DRIVES OVER. This is because to me it seems as if a robot that is driving over a baton therefore is in contact with the baton. Any thoughts?
Submit this question to the Q&A
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 12-09-2010, 00:47
Chris is me's Avatar
AKA: Pinecone
Keep in mind in FTC you're standing 6 inches from the robots. You could just drive the tubes over to where you're standing and look if you can't get the magnetic sensor to work as intended.
Unread 12-09-2010, 02:45
MWB's Avatar
MWB MWB is offline
Building and building.
AKA: Marcus W. Byrd
FRC #3716 (WABots)
MWB is just really niceMWB is just really niceMWB is just really niceMWB is just really nice
Send a message via AIM to MWB
hmmmm that may make things a little bit simpler...
Marcus W. Byrd
Team 3716
Lead CAD/Design and Fabrication.
Unread 12-09-2010, 08:03
Joachim Joachim is offline
Joachim has a spectacular aura aboutJoachim has a spectacular aura aboutJoachim has a spectacular aura about
Robots may not "lift, grasp or hold" the rolling goals (the only baton scoring locations with high points) except during the "end game." But I think teams will want to move them before then, as they are on the opposite side of the field from the dispensers. So get ready for Q&A stuff on what is and is not "holding" the goals.
Also, the "possession" definition (touching = possession) is worse than it looks, since the penalty is 5 points per baton over the limit, per occurrence. Just drive over 5 at once (or individually) while carrying 5 and you get -25. Also, according to <SG4>, robots may not possess a baton in possession of the opposing alliance without penalty (so don't drive over one that the opponent is driving over first).
A change from last year: Safety rule <S1> now adds "another robot" to the previous years' list of field equipment that, if damaged by your robot, is grounds for (discretionary) disqualification by the referees. So defensive strategies are getting riskier, especially if your competition includes lots of robots built last week.
Unread 12-09-2010, 10:00
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
I personally LOVE this year's game, although I think it will drive us krazy predicting what opponents will do in autonomous.
A defense robot could make getting the doubler impossible, just by driving in front of the dispensor. (Note you HAVE to get it in auto mode).
Also, looking at the video, the center of the movable goal appears to light up if there is a mag-batton in it. This will help with end-game scoring.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 12-09-2010, 10:07
alphadog0309's Avatar
alphadog0309 alphadog0309 is offline
AKA: Karan Hiremath
FTC #0110 (MFS Foxes)
alphadog0309 will become famous soon enoughalphadog0309 will become famous soon enough
The q&a isnt up yet its still only for the Hot Shot! game.... i guess ill have to wait until they set that up.....
Unread 13-09-2010, 11:56
normalmutant's Avatar
normalmutant normalmutant is offline
AKA: Nathan
FTC #3539 (Say Watt?)
normalmutant has a spectacular aura aboutnormalmutant has a spectacular aura about
The game will be a big challenge. We shouldn't complain about this. More rules can actually spur forth creativity in teams instead of inhibiting it. Our team can't wait to put together the field and start testing things out!
SAY-WATT.ORG
Unread 17-09-2010, 10:53
VashonRobotics's Avatar
VashonRobotics VashonRobotics is offline
AKA: Bruce
FTC #3861 (Vashon Pirates)
VashonRobotics is an unknown quantity at this point
I seriously doubt that any reasonable call on this rule will include any batons you drive over as being in possession. However I think the game Q&A does need to clarify this rule better.
For instance I can imagine a team making a deflector (like what a locomotive has) on the front of a robot to push batons out of the way keeping the wheels (or whatever) clear. Would that contact be considered possession? Maybe they should rule that if the batons are on the floor you can contact any number of them. Sure some teams will then push them across the floor to a stationary goal, but since bots are allowed to remove them that wouldn't matter a whole bunch.
I cannot find the game Q&A, is it open yet and if so where can I find it?
Unread 17-09-2010, 11:17
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Fun Fact: HiTechnic released the magnetic sensor the Monday following FTC kickoff. Reply from the Hitechnic guy on an inquiry about the stock:
This units are brand new and are in production right now. We should
hopefully start selling them within a week.
Regards,
Gus
HiTechnic Support
It's nice that they're only $23 too.
Another fun fact: Nothing in the rules says you can't launch the batons to the other side. I do not know why anyone would want to do that*, but it would definitely grab the audience's attention. This game will be boring to watch, but probably fun to play. As for design, I'll see how much sweat and tears the students put in before I say it's a good game.
*or do I????
GitHub
Unread 17-09-2010, 11:27
JesseK's Avatar
FRC #1885 (ILITE)
This would have to be situational at best -- why waste autonomous just sitting there? I would expect to see it at CMP, or in a couple of regional finals. It just adds to the unpredictability of autonomous I suppose. Juxtapose that with the concept that, by practical implementation, autonomous sequences are supposed to be predictable and you have one confounding paradox .
GitHub
Unread 17-09-2010, 15:39
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
But by even getting over, you still get 10 points even if there is a middle goal blocking bot. So, it is not too good of a strategy for preventing scoring.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 17-09-2010, 17:41
team F.T.C 4240's Avatar
team F.T.C 4240 team F.T.C 4240 is offline
Two cookies, one robot, all awesome
AKA: Derrick Maust
FTC #4240 (Techno Clovers)
Team Role: Driver
team F.T.C 4240 has a spectacular aura aboutteam F.T.C 4240 has a spectacular aura about
unless you push your rolling goal in-front of it, then go where ever you want after that
"Like" us on Facebook to get info and updates on the team: http://www.facebook.com/FTCTechnoClovers
2008-09: MD Finalist Alliance Captain, MD Inspire Award Winner, Worlds Division Finalist.
2009-10: MD Winning Alliance Captain, MD Think Award Winner, OH Winning Alliance Captain.
2010-11: MD Finalist Alliance Captain, MD Innovate Award Winner, DE Winning Alliance Captain, Worlds Edison Division Finalist Alliance Captain.
2011-2012: MD Annapolis Qualifier Winning Alliance, PTC Design Winner.
DE State Inspire Award Winner.
MD State Winning Alliance Captain, PTC Design Winner.
World Championship Franklin Winning Alliance, Thanks Landroids and Cougar Robotics!
[FTC]: FTC 2008-2009 Championship - your thoughts Abra Cadabra IV FIRST Tech Challenge 7 21-04-2009 00:02
[FTC]: Thoughts on new FTC game? Troubled FIRST Tech Challenge 45 07-12-2008 21:00
Thinking about starting a new FTC or FLL team? KathieK General Forum 2 29-05-2008 15:32
My Thoughts on the FTC Platform Change Ben Mitchell General Forum 28 20-03-2008 16:19
Thoughts about the future FIRST games David55 General Forum 7 24-05-2006 00:34
