Go to Post our electronics boards had begun to look like we'd planted a wire bush and it grew - daltore [more]
Unread 12-09-2010, 17:44
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Building a full size practice field
I'm looking for ideas and information on the construction of a full size practice field.
We have the space this year to build a full size practice field. We've also gotten a recent donation of enough carpet squares to cover the floor (cinching that this will be the year of the water game). I've started the planning process to build the practice field perimeter. I'm looking for plans and/or information about what others have done so I can do cost estimates for budget planning and estimates on the amount of effort to create a build schedule.
Thanks!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 12-09-2010, 18:21
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Building a full size practice field
My honest opinion on this would be if you live in an area rich with FIRST teams, like here in rochester , you have all the teams pool in on a full size competition grade field. You could also do it with something like this. I don't have much advice for you past this, but I think it's a great project and I'm waiting to see some of the other responses. So if you can try and get some other local teams, if any, in on this project that will help keep costs down for you.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 12-09-2010, 18:23
Look at the bottom of this page on AndyMark's web site: http://www.andymark.biz/offseasonfield.html
It points to a complete design package and says the raw material is about a thousand dollars.
The TechnoKats built ours a few years ago, adding game-specific parts every year (including the third gate for Breakaway). We bring it to IRI to be the practice field in the pit area. It was used as the playing field for the first C.A.G.E. offseason competition. It works great, and it's no great hassle to disassemble, transport, and reassemble it.
Unread 12-09-2010, 18:26
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Foster - I don't recal exactly where they to find them, but by searching the CD and/or FIRST sites you will be able to find plans for building a low-cost, but correct, FRC field from lumber instead of expensize modular, welded metal.
I think the thread I am remembering was active last year (2009-2010 school year), but it might be from 2008-2009.
Blake
[edit] What do you want to bet that Alan's URL points to the plans I am recalling? At least they appear to be equivalent plans.[/edit]
Unread 12-09-2010, 19:46
DonRotolo's Avatar
Back to humble
FRC #0832
IN any case, learn from our error and avoid iron pipe, regardless of the cost savings. That stuff is heavy!
Unread 12-09-2010, 20:11
Alan, thanks, that is what I was looking for. We used the practice field at IRI, I remember what it looks like.
Do you remember how long it took / how many people to build it? Any building tips that you can pass on?
As an aside can you tell me how long it takes you to take it apart and put it back together again?
Any other teams build this field?
Unread 12-09-2010, 23:37
If I recall properly, it was initially built over a period of a few weeks by two or three dedicated mentors and some sporadic help by a bunch of students.
The big tips I can give are obvious: measure carefully and try not to let things get out of square when building the pieces. Consider well whether you want to put polycarbonate panels or metal grids on the alliance station walls. While polycarbonate is probably better for safety, it's heavy, and it's harder to communicate through it when you're trying to debug a robot.
The field comes down in only about ten or fifteen minutes, given a half dozen people to carry things and a reasonable place to put it. Putting it together takes more time, since everything has to be placed within an inch or so, but I can imagine it being done in under a half hour if everyone is paying attention. I think laying and taping the rolls of carpet is what takes the most time.
[FTC]: Full Field vs Low-cost Field 595294001 FIRST Tech Challenge 13 04-05-2011 19:10
pic: Full Practice Field in Novi, MI - Open to All Teams LDavies562 Extra Discussion 8 06-03-2009 21:05
pic: Full Size playing field set up in our build space. Corey Oostveen Extra Discussion 6 12-02-2008 07:36
Building Practice Field robotrobot2 Technical Discussion 11 24-01-2008 01:54
Beacon Code on Full Size RC? Ian W. Programming 9 24-01-2004 12:41
