Go to Post This special is supposed to promote science, not convert the world to gracious professionalism (though that wouldn't be such a bad idea). - Karibou [more]
  #61   Spotlight this post!
Unread 29-06-2010, 17:29
Chris is me's Avatar
AKA: Pinecone
Re: Crazy Drive Train Ideas
Originally Posted by Tom Ore View Post
Not sure if this link has been posted earlier in the thread but here it is:
http://www.youtube.com/watch?v=L3NGCL-efRM
You'll note the machine in the video is running on a surface that deforms under the auger-wheels. How do kinematics when the surface fails work differently than on a stable carpeted surface?
  #62   Spotlight this post!
Unread 29-06-2010, 22:15
Best Available Data
FRC #1778 (Chill Out!)
This video seems to say it works just as well.
If any team wants to mold some enormous Archimedes screws like those, I'd bet you win some kind of technical award. Making weight would be fun though...
  #63   Spotlight this post!
Unread 30-06-2010, 07:26
Jared Russell's Avatar
Taking a year (mostly) off
Nobody is saying you can't get a screw drive to move - just that it will be much, much more inefficient than just about anything else on terrain that isn't sand or snow.
  #64   Spotlight this post!
Unread 30-06-2010, 07:36
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
With 130+lbs on the screws good luck not damaging the carpet from driving or getting pushed around.
  #65   Spotlight this post!
Unread 30-06-2010, 16:28
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
From the video, it looks like a rather high lead thread is required to get the speed ratios correct (fore/aft versus sideways). Maybe a multi start thread could be used to keep the lead high but provide more surface area in contact with the ground.
  #66   Spotlight this post!
Unread 30-06-2010, 16:37
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Maybe someone can have fun making an omni/mechanum auger. Get a big hollow drum and mount (or cut slots to hold) a ribbon of ball bearings, or of rollers, in a barber-pole spiral around the drum's outer surface.
I'm not saying it would be ideally suited for any games other than those containing the fabled FRC water hazards; but it could be fun to make. If you chose the materials carefully, you might be able to create a fun off-road machine that isn't stymied by swampy terrain, and that is also at home on FRC carpets.
Blake
  #67   Spotlight this post!
Unread 30-06-2010, 21:29
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Any idea on how it would work on corn?
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
  #68   Spotlight this post!
Unread 11-07-2010, 23:18
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
How about this?
  #69   Spotlight this post!
Unread 12-07-2010, 06:42
DinerKid's Avatar
DinerKid DinerKid is offline
AKA: Zac
FRC #1768 (Nashoba Robotics)
DinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of light
This will be my favorite robot of the day. That is totally sick. My mom walked by while i was watching it and thought it was real. I want to know what snake makes that sound though.
~DK
  #70   Spotlight this post!
Unread 14-07-2010, 20:14
penguinfrk's Avatar
penguinfrk penguinfrk is offline
AKA: Larry
FRC #1899 (Saints Robotics)
penguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of light
Cam drive. Worst mobility, best entertainment quality. You can only rotate the wheels in one direction, and if the wheels are placed on out of phase, you have this crazy tumbling thing. If put on in phase, you have a sort-of robot low rider that can pounce onto objects. If put on reflected, it's like a carousel.
How cool!
Larry
Saints Robotics 1899
High school intern at FIRSTWA
2011 Seattle Olympic Regional:
Website Excellence, FIRST Dean's List Award (for team captain Kevin Kimura), Tournament Winner (Thanks 3393 and 2990!), Chairman's Award Winner
  #71   Spotlight this post!
Unread 17-07-2010, 10:57
Bjenks548's Avatar
AKA: Brendan
Haha as cool as some of these ideas are, like the snake one , i was more looking for odd wheel arrangements like the close center wheel 6 wheel that 548swimmer posted a few weeks ago. We were also planing on making a jump drive before it even came on chief delphi, stuff like that.
  #72   Spotlight this post!
Unread 17-07-2010, 13:25
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Why is the snake surrounded by a blurry aura in that video? It is using a prototype cloaking device or...
Is the video perhaps a fake?
  #73   Spotlight this post!
Unread 17-07-2010, 21:55
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I think that's an artifact of the video compression.
I highly doubt that the video is a fake, here is the inventor's website, with all of the earlier and later versions.
  #74   Spotlight this post!
Unread 13-09-2010, 02:27
penguinfrk's Avatar
AKA: Larry
Gallop (Cam) Drive
(Change the phase difference for Low Rider drive!)
Larry
  #75   Spotlight this post!
Unread 13-09-2010, 19:51
Katie_UPS's Avatar
Katie_UPS Katie_UPS is offline
AKA: Katie Widen
FRC #1296
Katie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond repute
I always wanted to see a big-wheel robot.
How To: Diversity and Inclusion in FIRST
1675->3928->1296
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
drive train Adama Technical Discussion 30 14-12-2006 20:56
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Drive Train Thunder360 Motors 5 21-03-2003 20:41
Drive Train archiver 2000 1 24-06-2002 00:37
