Go to Post I think the "F" in FIRST really stands for "friendly." - Rick TYler [more]
  #46   Spotlight this post!
Unread 12-09-2010, 16:35
Re: Are they really robots?
Originally Posted by RoboMaster View Post
It certainly wouldn't be a robot if it was completely mechanical parts.
again, why?
if it has a power source, and sensors, and actuators, and a computer to process the signals from the sensors and send commands to the actuators, why is it not called a robot simply because it has no electrical or electronic parts ?
  #47   Spotlight this post!
Unread 14-09-2010, 23:36
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
It certainly wouldn't be a robot if it was completely mechanical parts. That's a machine or tool. I'd think that would be too direct to be a robot.
Not neccessarily, if the mechanism is designed to react in response to stimuli (read as forces) in a way that could be considered interaction, that might be debateable. Remember, People have built mechanical computers before, not much needs to be done from there to get a robot.
EDIT: Autonomy is more direct than remote control. why then does a MORE direct system disqualify the device as a robot?
  #48   Spotlight this post!
Unread 14-09-2010, 23:49
A robot is any object that passes inspection.
  #49   Spotlight this post!
Unread 14-09-2010, 23:52
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Ok, I see where you're getting at. You're right, I guess that would count, but that's like a really specific ambition project for no electronics, like what I mentioned before:
I know what can be done with just mechanics, but I'd be pretty impressed if you were able to make a full fledged "robot" like a hobby robot out of just mechanical parts.
But what I was talking about was more general, like my other example:
...if you scrapped all electronics on your FRC robot, had a really long hand crank with a universal joint that gives power to the wheels, and a similar hand crank for directly altering the steering. That's more of a very fancy mechanism.
I would take that to be a mechanism that has interaction (with forces), not something that interprets signals and "thinks" on some level.
That's confusing to me. Autonomy is more direct in that there's no "middleman," but it's more *complex* in that the robot really thinks and decides. When I say more direct, I mean less thinking/interpreting signals and just direct movement/action.
Hope that helps; does that portray my ideas?
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
  #50   Spotlight this post!
Unread 15-09-2010, 09:56
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
This is where you're getting tripped up I think. A program that makes a decision is executing a series of equations and performing an action based on the answer. There is no reason why a mechanism couldn't be designed to perform the exact same calculation and take the exact same action based on the answer. The reason that it's not done normally in real life is complexity, size, and efficiency.
Check out this very cool machine that uses several "binary mechanical computers." These computers are programmed by placing pins in different locations, but they are computers none the less. Their final machine will use sensors to synchronize the clock with the rising sun through the use of shape-memory alloy wire and a very unique lens.
  #51   Spotlight this post!
Unread 15-09-2010, 10:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Might be off topic a bit, but consider the carburetor, vs electronic fuel injection. The carburetor is a relatively simple mechanical device that uses some pretty basic principles to meter fuel quite accurately under many different operating conditions. EFI uses a computer, several sensors, several actuators, a sort of complicated program, and calibrated lookup tables to do the same job.
I doubt either is really a robot, but the analog mechanical device is my favorite if I'm the one paying for and maintaining the thing.
  #52   Spotlight this post!
Unread 15-09-2010, 11:52
Or consider a gas turbine engine fuel control. Up until about the early-70s, these were analog hydromechanical computers. They consisted of 3D sliding cams, spinning flyweights, EDM-contoured valves, servo valves, check valves, pistons, levers, pressurized metal bellows, helium-filled coils, etc etc.
  #53   Spotlight this post!
Unread 15-09-2010, 12:04
R2D2DOC's Avatar
R2D2DOC R2D2DOC is offline
AKA: Laszlo Hideg
no team (Judge & Volunteer)
R2D2DOC will become famous soon enoughR2D2DOC will become famous soon enough
Please navigate to:
http://www.robotics.utexas.edu/rrg/learn_more/history/
and you get:
According to the Robot Institute of America (1979) a robot is:
"A reprogrammable, multifunctional manipulator designed to move material, parts, tools, or specialized devices through various programmed motions for the performance of a variety of tasks".
With this debate, we will see what the community thinks when the BSA Robotics Merit Badge is published April 2011.
  #54   Spotlight this post!
Unread 16-09-2010, 20:22
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
I think a lot of people - laymen - think of a "Robot" simply as a mechanical man. A machine that mimics the shape and motion of a human.
From that perspective, many people would think our machines weren't robots, but some other kind of machine.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
  #55   Spotlight this post!
Unread 25-09-2010, 14:24
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Originally Posted by dlavery View Post
I dunno, perhaps "FVC"?
Hmmm ... that's a vaguely familiar acronym ... where have I heard that before?
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
  #56   Spotlight this post!
Unread 25-09-2010, 22:05
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
I think they are robots.
Every time the operate moves the joystick, presses a button, or something else he is sending a signal (which acts the external stimuli) to the robot telling it to execute a piece of preprogrammed code in response.
In even more abstract sense you could think of the driver station as a big sensor array. The driver is creating the external stimuli that in turn makes the robot execute a preprogrammed response.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
  #57   Spotlight this post!
Unread 25-09-2010, 22:28
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Then what makes that different from a gaming console? It does preprogrammed response on the screen, responds to external stimuli...
  #58   Spotlight this post!
Unread 25-09-2010, 22:30
Chris is me's Avatar
AKA: Pinecone
Gaming consoles are not machines; they're not largely mechanical. At most, they have vibration functions. Robots have mechanical emphasis.
  #59   Spotlight this post!
Unread 26-09-2010, 11:10
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Are they Robots?
I think the various messages in this thread have unequivocally established that the answer to this question is: "Of course they aren't robots; they are obviously and unambiguously robots."
  #60   Spotlight this post!
Unread 29-09-2010, 01:33
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Any machine that is computerized is a robot.
-Isaac Asimov
I think that should about sum it up.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Are these wheels available, anf if not are they ever gonna be? Elgin Clock FIRST Tech Challenge 3 12-11-2005 22:27
Robots really are nuclear powered suneel112 Electrical 14 25-04-2004 12:25
Are your engineers really what they seem? MissInformation Chit-Chat 11 18-12-2002 12:54
M12 and Q12 -- do they really mean this? archiver 2001 1 23-06-2002 22:45
