Go to Post As long as they're not destroying each other, LET THE TEAMS PLAY! - Travis Hoffman [more]
Unread 16-09-2010, 00:09
Mountain Man's Avatar
Mountain Man Mountain Man is offline
FRC #2614
Mountain Man is an unknown quantity at this point
Custom "Car Style" Drive System
As a part of the Mountaineer Area RoboticS (MARS) 2614 team's internal "pre-season" competition, the Deimos subteam has decided to make an unconventional yet innovative "car style" drive system. It incorporates a differential to distribute power to the rear wheels while the front wheels are steered with a tie rod steering system.
Here are pictures of the differential. More pictures to come as more things get assembled.
Unread 16-09-2010, 01:26
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: Custom "Car Style" Drive System
Where is the input on the differential?
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 16-09-2010, 01:55
AdamHeard's Avatar
Lead Mentor
It seems like you may want to actually remove the bearing on the idler bevel, right now you have a fully open differential. If you replaced it with a bushing of higher friction (or even better, some sort of clutch setup), you could easily integrate a limited slip differential for better performance.
I would assume a sprocket or gear will be fastened to the face of the housing.
Unread 16-09-2010, 02:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I too am curious where the power will be input to this device. Typically it is driven through the case/housing/carrier.
The design also has a problem, in that each gear is supported by only one single-row bearing. You need another bearing on there, close by. Then use a coupling or universal joint to get the power out and away from the unit. Basically, make the differential it's own robust unit. Shorten those shafts, and have separate ones that go out to the wheels. The alignment of the gears should not rely on a bearing that is many inches away down the shaft, located on a completely separate mounting piece. As shown, the gears will wear quickly, and possibly bind.
As Adam said, some sort of friction clutch (perhaps even adjustable) on the center gear could be beneficial, to help prevent single wheel burnouts. Watch the movie "My Cousin Vinny" It is explained well.
Remember, design with the idea that you may make it to finals, and you wouldn't want it to be on the verge of failing when the stakes are high.
Unread 16-09-2010, 02:21
rahilm's Avatar
AKA: Rahil Mehta
Edit: Never mind, wasn't thinking straight
Unread 16-09-2010, 11:03
FRC #2614
Correct, there will be a sprocket for chain attached to the side of the housing. It will be driven by an AndyMark toughbox situated above the differential.
There will be "mounting brackets" that contain bearings that the shafts will go through to support the weight of the robot. There will be one on each side very close to the differential and one just inside each wheel out at the edge of the frame.
We have tossed around the idea of a "clutching" mechanism on the idler shaft to limit the slip. This is the first prototype, however, and if we do decide to use something like this for competition we will more than likely have to improve the robustness of the design.
Unread 16-09-2010, 12:02
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
It certainly is unconventional in FRC, but is there some trick that makes this innovative in the grand scheme of things? Still unique either way.
For bonus points, drive your front wheels with hub-mounted CIMs on planetary gearboxes or even through more beveled gears.
Unread 16-09-2010, 12:44
I am just an electrical guy but in this configuration don't the two output shafts rotate in opposite directions? Is this only the inner mechanism and you intend to add an additional mechanism that it is rotated by the drive motors? If that is the case, wouldn't a second idler, opposite the one shown, be a good idea to distribute gear loading?
Unread 16-09-2010, 12:49
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's a differential, as mentioned the square tubing housing is the "input", and the two shafts are the "outputs". If either wheel loses traction, then the other wheel won't be driven, as the slipping wheel will just turn at twice the "input" speed.
Differentials are great in cars, but I don't really see much application in the robots we build. Might be because we don't intentionally push our cars up against other cars, or barriers....which is natural FRC robot behavior.
Unread 16-09-2010, 13:58
Aren_Hill's Avatar
Build Nifty Things
right there is a beautiful example of a differential setup from 2008, team 34 i believe.
(roboticWanderor's picasa gallery of awesome)
adjustable limited slip
A guy who likes robots.
Unread 16-09-2010, 14:07
That's just darn pretty!
Unread 16-09-2010, 14:12
Thanks Aren, that makes a whole lot more sense now!
Unread 16-09-2010, 14:19
Thanks, Jim. A Michigan Team (GM sponsored) had a four wheel drive robot with differentials many years ago. It was surprisingly compact. It had some issues, but was interesting to look at.
Unread 16-09-2010, 15:23
MrForbes's Avatar
AKA: Jim
If you want to really show off your machining skilz, make a Torsen differential. It acts like a limited slip, but requires no clutch.
Unread 16-09-2010, 15:24
-=Pz=- -=Pz=- is offline
FRC #2935
Team Role: Student
-=Pz=- is an unknown quantity at this point
That does look sweet piece of work
"Hopping" With tank style turning. QuantumNinja Technical Discussion 22 19-02-2006 15:11
pic: Lavery and his "other car" CD47-Bot Extra Discussion 11 03-05-2004 11:24
Thread Style not "sticking" Clark Gilbert CD Forum Support 1 01-12-2003 20:47
"Custom" Segway Keys for sale on Ebay MattK Dean Kamen's Inventions 4 22-06-2003 00:01
Dave Lavery is insane!!! lol Krispy Kreme Drive Through "car" Elgin Clock General Forum 16 11-03-2003 23:19
