Go to Post What language does your programming mentor have the most experience with? That's the language you should use. - Rosiebotboss [more]
Unread 19-09-2010, 17:42
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
pic: 2 Speed Rev 2
Unread 19-09-2010, 17:44
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
Re: pic: 2 Speed Rev 2
You know RC... I'm not surprised by this Your CAD always looks amazing! Your work is very impressive! Very clean and elegant!
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
Unread 19-09-2010, 18:13
Chris is me's Avatar
AKA: Pinecone
Nice model / gearbox!
How often did you guys play at 16FPS? When looking into drive boxes this year, I was looking at the 6 motor setup, but it seemed that adding 6 motors let you run at ~9.5 FPS while pretty close to traction limited. Was the high gear useful for your team, or just something nice to have?
Also, can I have two?
Unread 19-09-2010, 21:39
Originally Posted by R.C. View Post
-16 FPS and 8 FPS
what are the gear ratios ??
Unread 20-09-2010, 02:58
R.C.'s Avatar
Chris,
Hmm interesting question, I don't know if we ever got up to the full 16fps. I don't have anything quantitative but:
-We were quick
-The acceleration was amazing
-It was nice being able to get from one side of the field to the other rather quickly.
In a match we stayed in high gear the whole time except crossing the bump and pushing. Our driver absolutely loved having the high gear and we would not hesitate to gear this high again. Lol, sure Chris to go?
Ether,
I added more info to the pic:
-6 Inch Wheel
-Initial: 12:50
-Shfiter: 28:48 & 16:60
-RC
R.C.
MadTown Robotics Team 1323
Unread 21-09-2010, 09:57
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
How do you do the shifting? Pneumatics, servo motor, or some other means? Did you cut the gears or use off the shelf gears?
Looks nice.
- T
-T
Unread 21-09-2010, 10:59
R.C.'s Avatar
Looks nice.
- T
The shifting is done with pneumatics and all the gears used in this render/model are bought off the shelf.
-RC
R.C.
Unread 21-09-2010, 15:16
topgun's Avatar
Can you show some alternate views of the gearbox?
-T
Unread 24-09-2010, 01:25
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Dude looks sick!
I am learning SolidWorks at school now, Its a really nice program.
Good enough is the enemy of anything great!
team 1671
Unread 25-09-2010, 00:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Can you get rid of any of the standoffs in there to simplify it a bit, and reduce the parts count?
Unread 25-09-2010, 15:30
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Hi RC
Thank you for sharing. You have been busy. If you did this with SolidWorks Photoview 360 you really should put this image up on www.solidworksgallery.com. Very nice work. Marie
Unread 25-09-2010, 16:20
AKA: Pinecone
One more question: Why two 1/4 plates and not 1/8 plates with bearing shims? I haven't made many gearboxes or anything, so I'm trying to look into the advantages of one over the other.
Unread 28-09-2010, 19:36
J93Wagner J93Wagner is offline
Where'd all the time go?
AKA: Jonathan Wagner
no team (Formerly N.E.W. Apple Corps)
J93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to behold
@Chris - If I had to take a guess as to why there are no flanges, I would say it has something to do with DFMA as not every team has easy access to bending parts accurately (we certainly don't), or ease of access and assembly.
Also, what exactly is the plate thickness? I need to know for a project I'm working on. Nice gearbox btw.
My personal favorite quote: "There is nothing better than being proud of the things you love." -Sean "Day[9]" Plott
Unread 29-09-2010, 02:15
R.C.'s Avatar
David,
This gearbox was made for our 2010 robot. The only reason for the extra four standoffs are just so the gearbox stays together at all times. The other four standoffs are just purely for mounting.
If I was going to do this again, It would not have as many spacers.
Originally Posted by mplanchard View Post
Hi RC
Marie,
It was indeed rendered with Photoview 360, I'll definitely put it up when I get a chance.
Chris,
The reasons why I use 1/4" Plate over 1/8" Plate
-Stiffer
-Can be tap'd
-Thickness for bearing
-Allows for counterbores
This is 1/4" Plate.
Thanks,
-RC
R.C.
Unread 01-10-2010, 09:41
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
sick model dude!!
pic: MadTown Chassis Rev 4 R.C. Extra Discussion 19 16-12-2009 17:20
Renumbering of rules in rev F and Rev G of section 8 Joe Ross Rules/Strategy 3 02-02-2009 21:46
pic: Evolution of a gearbox rev 4 roboticWanderor Extra Discussion 9 27-05-2008 09:19
